RazorRacer's Avatar
SC Heater engine compartment blower removal...
How do you connect the outlet of the engine fan direct to the two heater hoses and bypass the engine compartment blower?
Does an aftermarket part exist?
BTW, removing this blower won't make a difference because it has never worked and the heating works fine without it.
Stopped racing and became a drummer
Old 01-11-2003, 06:43 AM
Sean Hamilton's Avatar
I simply removed the fan assembly out of its housing, duct tapped the internal voids where the fan used to be so air wouldn't escape in there but rather directed immediately through the existing ductwork.
I bolted the housing back in place, hooked up the ducts and, yes - so long as you are in motion it works fine without the fan, even with the climate control.
For a neater job, as you're suggesting, Pelican sells a heater "backdate" kit if I recall. I stumbled across it somewhere in a "search".
Cheers, Sean.
94 911 Carrera 2 993 Cab
http://www.pelicanparts.com/gallery/Sean_Hamilton
Old 01-11-2003, 07:05 AM
Jbabic's Avatar
just back date the heater system.. much cleaner, doesn't cost much. there are plenty of threads on this on the BB. I got mine for around $50 used...but you can buy new. much cleaner look. I can email pics if you like
Old 01-11-2003, 07:25 AM
RazorRacer's Avatar
Thanks guys. Babic, you are right, there are quite a few threads posted. Here is a good one to do the complete backdate:
related thread #1
However, I'm asking:
Is there's an existing part for keeping the fan shroud current, but ducting are to both exchangers? Unless something already exists, I'm thinking of making a splitter out of a thick, high temperature fabric.
Old 01-11-2003, 08:02 AM
Original Owner
tsuter's Avatar
To back date the heater for a 911SC you need the following parts:
911-106-327-00 Heater Duct
911-106-321-00 Heater Duct
911-106-036-00 Cover Plate Large
911-106-827-00 Cover Plate Small
911-211-194-00 Heater Duct Hose
Got rid of my heater blower in 1982.
Living in Hawaii and didn't need it.
tsuter
78 911SC Turbo Targa
Thaaaats Right!!
Old 01-11-2003, 09:32 AM
Hopelessly Addicted
Porschephanatic's Avatar
Arrow
tsuter has got it right. With the backdated heater ducts, you'd be amazed how much tidier the engine bay is!
Old 01-12-2003, 04:09 AM
RazorRacer,
To answer your question No. I think you are on yer own.
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 01-12-2003, 06:39 AM
Original Owner
tsuter's Avatar
The cover plate does not interfere with the AC compressor bracket and compressor. I needed the AC in Hawaii but needed room on the left side for my turbo pipes and the heater blower motor was in the way over there. As was that silly air pump.
tsuter
Thaaaats Right!!
Old 01-12-2003, 08:21 AM
Backdating SC Heater
JBabic,
Could you post a picture of your set-up? Thanks.
Old 01-12-2003, 04:12 PM
Paul Sopp's Engine
note cool collar?
Cheers, Sean.
Old 01-12-2003, 10:48 PM
