Tie Rod big nut?
Any tips on getting the big locking nut off the tie rod/steering rack? It is the thin locking nut. Do I need a special wrench?
Thanks!!
Doug '67 911 2.2 |
Rather than buying the special wrench when I replaced tie rods on my 87 I simply used the two nuts from the tie rod ends, locked 'em against each other and then used a socket wrench to unscrew the tie rod from the steering rack. It couldn't have been easier.
my early car has a lock nut against the steering rack. I have seen threads of a notched ring, but this is a big thin nut that is hard to get to.
Doug '67 911 2.2 |
Disconnect the ball joint end of the tie rod first. Then use the tie rod itself to break that fitting loose - push it sideways and use it as a lever. Then spin it off by hand. I just followed this same method last weekend when replacing mine - I believe it's mentioned in Wayne's book. No special spanner wrench needed for removal.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
bump
Doug '67 911 2.2 |
Montana 911
agree with Mark, no special tools needed...hell if I can do it this must be an easy project!
H.D. Smith 2009 997.2 S 3.8 PDK 2019 Ford Ranger Lariat FX4 Baby Raptor 2019 Can Am Renegade 1000R XC 2020 Yamaha YFZ450R |
