AFM vs. MAF. 30 years and going strong?
I have meant to ask this question for some time.
Our 911 AFM never seems to be replaced. In fact, it seems like an NLA part. Modern cars commonly need a new MAF after 10 years or 100k miles. I assumed MAF and AFM were the same thing. So, I found this online. Why don't AFMs ever need service? Is the AFM door flap mechanism is a mechanical, reliable potentiometer where a MAF has a delicate filament that is prone to failure? Quote:
1986 Bosch Icon Wipers coupe. Last edited by sugarwood; 01-01-2017 at 04:37 PM.. |
They do occasionally need service. The moving door has a contact wiper that can wear out its curved contact path, leading to unreliable measurement of airflow. It can be addressed, but like all mechanical devices it does wear. OTOH it it an extremely reliable and durable analog device.
Dave
Dave McKenzie 1984 Carrera 3.2 1984 928S Automatic 2001 996TT |
Not true, search around here. Lots of poor-running is traced back to the AFM. The wiper that forms the variable resistor with a track wears out the track it moves on. As a result the AFM signal is no longer continuous but has distinct jumps and that messes with the mixture.
Here is one example: [3.2 Motronic] Air Flow Meter wiper arm re-tracked - WOW! There is a simple test with a 9V block battery and a volt meter to check the response of the AFM throughout its range. Again, the search function is your friend. ![]() Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
1. Don't get damaged during an engine backfire where the flapper is bent. 2. Are maintained with the carbon track and the flapper pivot points lubricated with a light oil every 5+ years.
Dave |
^^ Any DIYs on maintenance of the AFM, oiling, etc?
Kurt |
^^ Ingo's link above is a start.
1986 Bosch Icon Wipers coupe. |
