-   -   Targa body flexes when jacked up? (http://forums.pelicanparts.com/porsche-911-technical-forum/940910-targa-body-flexes-when-jacked-up.html)
universeman 01-01-2017 09:49 AM
Originally Posted by scold (Post 9415079)
Makes me wonder - if you have a cab/targa, is it better to lower the cab top/remove the targa panel before raising the car since not doing so would seem to suggest that undesirable forces would then be applied to the cab top/targa panel fixing points?
There's a lot of slop in the top mounting on a targa -- plenty to keep it from binding under any amount of flex that would be considered normal...when mounted there is at least an inch to the back between the top structure and the roll bar. The vinyl part of the roof is tighter tolerance but it can flex also so not a problem.
Good thought though. I don't have a cab but would imagine it's a similar story there.
OsoMoore 01-01-2017 02:20 PM
I put on my Targa top when keeping the car jacked for extended time (like an engine drop). That seemed to reduce the flex and ensured I could open and close the doors.
