Functionista
manbridge 74's Avatar
Consider replacing fuel lines if they are old style single crimp where rubber section meets metal. New Porsche ones are double crimp and pricy. I'd take them to a hydraulic shop and have them made.
The cross shaft that supports your TOB arm is available with updated parts (bulletin from Porsche on this) if yours is worn out or badly corroded.
Don't over torque fan/alt assembly when re-installing.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 01-06-2017, 09:25 PM
Tori's Avatar
Bare with me fellas while i ask some possibly dumb questions.
I'm to the point of removing the timing bits and camshaft housings.
The book i have really only addresses pulling the motor completely apart. I don't intend to split the case, and wonder where can i stop in taking the timing chains loose in order to get the camshaft housing off.
Can i just remove the tensioner, idler, and then pull the chain off the cam sprocket ? Then after the sprocket is removed from the cam, can the cam housing be removed leaving the rocker arms installed ?
1987 911 Carrera Coupe
1987 Buick Grand National
1971 Plymouth Roadrunner
Old 01-07-2017, 03:36 PM
Tori's Avatar
...okay, i see now that the rockers do need to come out to access the nuts underneath.
Old 01-07-2017, 04:32 PM
Tori's Avatar
So what's the lifespan of the hydraulic tensioners ? 106K on mine.
and what's the opinion on the oil return tubes. Go with the solid ones at this point i would imagine. ?
Old 01-08-2017, 08:22 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Just be careful and compress them slowly as not to damage them internally to put the lock pin in ( I used a coat hanger ) the recent replacements are poorly made so try your best not to damage yours.
I was thinking the same, but I like the idea of maintenance so I will be sticking with the collapsible ones.
'85 Carrera Targa
PCA/POC
Old 01-08-2017, 09:54 PM
michael lang's Avatar
When I was doing mine, I remember reading something about the tensioners being hard to depress to get the locking tool in place and that if you could depress the pin with your fingers it was no longer a usable tensioner. So I used that as my guide. I could not so I reused the ones I had. As far as the oil tubes are concerned, I was not experiencing any leaking from the ones I had so I could have gone with the solid ones or replace the seals on the collapsible ones that I had. I went with the new solid and cleaned up the collapsible ones in case I ever need to replace one.
Mike
'89 CARRERA
#402
Old 01-08-2017, 11:30 PM
Tori's Avatar
Yep, that's what i had planned to do with mine. I have the two piece tubes as well. Might as well eliminate 4 potential places to leak.
Old 01-09-2017, 07:37 AM
theiceman's Avatar
always replace with solid tubes, besides the reason mentioned above anyone looking at your car in the future may consider ( as I would ) corner cutting during a build and discount the car.
Besides it looks totally cool with the one piece !!!
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 01-09-2017, 08:54 AM
Tori's Avatar
man, that is one crooked door !
Old 01-09-2017, 09:08 AM
Probably a slanted garage floor to promote drainage....
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 01-09-2017, 09:39 AM
DRACO A5OG's Avatar
Then you need to keep your OEM, rear fuchs, muffler & cat too
'85 Carrera Targa
PCA/POC
Old 01-09-2017, 10:54 AM
Tori's Avatar
Darn it Jim, you ruin all my fun.
Gonna reassemble my p-motor as a radial.
Old 01-09-2017, 11:28 AM
Tori's Avatar
A quick update... heads are now cross country with Craig getting a full makeover, guides, valves, seals, and surfaced. Parts are trickling in as I go... today the clutch throwout shaft upgrade and firewall insulation pad from out host arrived. Still looking for a good used stock Alusil cylinder and piston, and got a little pretty boy work done this past weekend while the sun was out.
Working on getting the Dilavars out now. So far 5 have come out easy, but one on #4 wants to see what I'm made of. But I showed it, after trying a couple times with heat I gave up and went to finish my cocktail and have supper
Old 01-23-2017, 09:10 PM
Always Be Fixing Cars
Looking good. Regarding the clutch cross shaft upgrade: I bought one here, installed it about 3 years / 20k miles ago, no winter driving but some rain, tried to pull it this weekend. Stuck TIGHT from corrosion. I had to fabricate a puller and it came out shreaking and chattering all the way. I took great pains installing it the right way and was a bit disappointed since the original arm that was likely in the car since 1987 came out with a few taps and finger pressure.
'87 Coupe GP White / Crimson
'73 Alfa GTV bare metal project
'65 Painted Dash 912 project
Old 01-25-2017, 05:23 PM
DRACO A5OG's Avatar
Brother Tori,
If the studs start chattering out, stop and turn it back, lube and tap it and start again, this will limit tearing out the aluminum.
'85 Carrera Targa
PCA/POC
Old 01-25-2017, 07:09 PM
Tori's Avatar
that's disappointing to hear about the cross shaft. with any luck i'll never find out if mine ends up the same way.
Jim, I've got all the studs out except this one bastard that is fighting me. I'm being careful not to break him, but at this point i can no longer get a good bite on it with the vise-grips. I keep forgetting to bring home a different type of stud puller from work so there it sits....
Old 01-25-2017, 08:46 PM
Tori did you try double nutting? This worked very well for me in removing all my headstuds. I also hit the base of each with a blast from the MAPP.
Old 01-26-2017, 04:56 AM
Tori's Avatar
haven't tried that yet, not sure i can get nuts on the stud threads now. That's where i was putting the vise grips. They would not get a good bite anywhere else. Impressed at how hard these Dilavar studs are.
Old 01-26-2017, 09:22 AM
Project Addicted
The simple rolling type stud removers work really well for this task. Should be availble almost any parts store
Jon
1966 912
1976 911 3.4 Backdate Project
1986 944
Old 01-26-2017, 05:57 PM
Tori's Avatar
ah yes, i think we have one of those. Now if you could just call me tomorrow between 8-5pm to remind my dumbass to grab one from work.
Old 01-26-2017, 06:02 PM
