-   -   More agressive alignment needed. what specs? (http://forums.pelicanparts.com/porsche-911-technical-forum/94106-more-agressive-alignment-needed-what-specs.html)
tight as a bull's ass 01-13-2003 03:45 PM
I'm taking my 83 sc to the shop tomorrow to have a more aggressive alignment done on the wheels.
It's a daily driver but I also what to have it track ready in case I decide to do some auto-xing in the spring...I currently have a set of Kumho Ecstas Supra:
205/55WR-16
225/50WR-16
Can someone tell me what specs I should get in terms of camber/toe-in, etc?
thanks.
TimT 01-13-2003 04:30 PM
how much track and how much street time?
Front:
as much camber as you can get
as much caster as you can get
set the toe to zero
Rear:
As much camber as you can get
set the toe at 1/4" total (this would be toe in)
pbs911 01-13-2003 04:55 PM
At least 1.25 negative camber in the front and 2 in the rear. that's where mine are with 1/8" toe in. Fun set up. A little darty in the grooves in the street but not unsafe by any means.
But everything must work together. I have 2230 lbs, 21/28 torsion bars, 225/45 and 255/40 Kuhmos, Bilstein Sports rear, HD in front, Drop link bumper steer, lowered so front spoiler is at 2.5" @ front 25" from ground to wheel well in front and 24.5" in rear, 86 Carrera sway bars, and poly bushings everywhere.
tight as a bull's ass 01-13-2003 05:04 PM
I would say 98% street time and 2% track time...
I want the steering wheel to feel "tight" but not so tight that I can't bear it....I drive on the highway most of the time with very few left and right turns..
My set-up is:
Bilsten sport shocks all around
turbo-tie rods
Euro-spec ride height.
currently no sway bar.
205/55WR-16
225/50WR-16
masraum 01-13-2003 06:28 PM
I have heard...
Front
camber 1 - 1.25 neg
caster as much as you can get
toe 1/32
Rear
camber 1.5 neg
toe 1/16
SC with no sway bar?? I thought the last time they did that was back in the late sixties or early seventies?!?
ChrisBennet 01-13-2003 07:40 PM
I basically run what Steve suggested and I don't have any dartyness or weird tire wear. I do 6-10 track days a year and it is a good compromise.
If you or someone decides to go with the setup Tim suggested be aware that when you increase camber in the rear you increase toe out. You can only increase the camber to a certain point (1.5 deg on my car) before you can't adjust the toe into range. A race shop familiar with 911's can get around this but a "normal" alignment place wouldn't be able to.
-Chris
