High speed brake shudder
I'm having high speed brake shudder like when you must suddenly brake on the freeway. I feel it through the peddle. Its like and sounds like going through gravel. Low speeds are fine . Around town on back roads are fine. I took the car to my favorite shop and had both front rotors turned. pads are very new I bought from Pelican. So I got back on the freeway for a test and nothing has changed. Like going through gravel. I inspected the rear rotors and they look smooth and clean. Any ideas what could cause this problem. Than you.
Front wheel bearings
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
Diss Member
+1
If it isn't brake rotors then it is very likely it's precessional tramp. Grab the top of the wheel and rock it in and out and see what kind of slop it has.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Also check tie rod ends
cycling has-been
You don't identify the car that's affected.
On the M calipers, the pistons should be clocked so the trailing edge of the pad contacts the rotor first - something like 10 degrees. Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera Last edited by bkreigsr; 02-07-2017 at 10:03 AM.. |
Grappler
Warped rotors can also cause brake shudder.
Grappler Know Gi / No Gi 1976 RSR Backdate (Turbo 3.2) |
OK, Ill check those things. Meanwhile it is back at the shop to have rear rotors turned. Sorry, its my 85 911 Carrera.
Caveman Hammer Mechanic
New Brakes!
Even though some say bedding is not necessary, I will disagree. Have done it on Cessnas and cars, all as per the manufacturers installation instructions. My stuff was just OK, after bedding WHOW!
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 Last edited by ClickClickBoom; 02-07-2017 at 11:07 AM.. |
Slippery slope skier
Nick, have you done any track events recently?
Shudder is often caused by "pad imprints" transferred to the disks. https://www.zeckhausen.com/catalog/index.php?cPath=6446_6444
'85 930 ...the oil leak rebuild which mutated into more than I could chew... then came back to my senses and climbed "back up" the slippery slope! A stock 930 is far better than an incomplete project car! 930 rebuild – The revival of my mothballed project |
Yep, after several days of high speed track braking I have shudder too...
I think there is a way to re-bed the pads with quick short stops from speed.... |
RETIRED
Could be brake pad clumping from your event. A couple up to 60 and gentle braking down to 20 a few times might clean it up. Happened to me at Willow Springs but I was able to clean them up on the cool down lap.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Brake shudder solved! I had the front rotors turned yesterday and the problem was still there. Today I had the shop turn the rear rotors and shudder is gone! Mechanic told me that shudder in steering wheel is front rotors, shudder on the peddle is rear rotors. Everything is good but now I have a harmonic sound while normal braking coming to a stop sign. starts while I'm braking, then noise fades away. Everything looks good. Not worried. Much better than the heavy shudder while hard braking.
Ova Day
That could be a caliper dragging caused by a piston not returning. In my case it was ancient rubber brake lines. They actually close up and restrict flow. New lines fixed that issue for me. I wonder if a dragging caliper would cause a rotor to overheat and warp.
88 Triple Black 911 Carrera Cab, ex Garage Queen 05 BMW E46 M3 21 Tesla Model 3 LR 08 BMW 328xi 15 Ford F150 |
1987 911 Carrera coupe - Guards Red 2010 997.2 C4S 6-Speed 2005 Mini Cooper Convertible (R52) - Wife's car 1977 VW Bay Window Camper Bus |
