Cat By-pass with Muffler recommendation
I'm considering installing a Cat By-pass / muffler combination on our 1983 911SC. My challenge will be replacing the cat converter when its time to pass emission testing. Appreciate any product recommendations or thoughts on my plan to swap out the by-pass when needed.
1983 911SC 1954 Rolls Royce Silver Dawn |
El Duderino
You can put in a straight pipe or test pipe or a Euro pre-muffler. Both should be drop-in replacements for the stock cat.
Doesn't CA have random roadside inspections? Seems like I recall reading other members mention that. If so, what's the penalty if you get busted?
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. |
Roadside inspections are VERY, VERY, let me repeat... VERRRY rare. I wouldn't and don't let that stop me. I've installed a euro-premuffler (looks like it belongs there) and a Dansk 1 in, 1 out 70mm muffler. Sounds fantastic to me. It's not loud, but has a nice rumble at lower speeds which goes away at hwy speeds. For me, no drone sound or loudness increase in the cockpit was important to me. I'm very satisfied. When smog time comes around, it's an easy swap to re-install the cat.
https://www.youtube.com/watch?v=lV09CTxjhFI https://www.youtube.com/watch?v=v0PR3ULe35I
1987 911 Carrera Coupe 1987 Buick Grand National 1971 Plymouth Roadrunner Last edited by Tori; 01-04-2017 at 09:50 PM.. |
I have M&K pre muffler and 1 in 1 out muffler on the 88. Very nice quality and sounds good too. As mentioned in a previous post, pre muff looks like it belongs and it would be relatively easy to remove and replace with cat for inspection.
gary 70T coupe forever almost done 88 Carrera Targa diamond blue |
Member 911 Anonymous
+1, get a test pipe that looks like a cat to pass the initial visual if you are unlucky enough to get caught at a random smog test net by the CHP. In my neighborhood, 5 years ago I was directed to one when going down the usual road. Don't try to turn around CHP will go after you if they see you.
+1, I really like my dansk muffler with the euro pre-muffler with O2S bung plugged in.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
I'm not sure if I posted this, so I apologies if I have? My 87 cab had after market muffler (1 in 2 out). After much research, I went with M&K pre muffler & muffler. Here's a pic. Love the sound!
Terry ![]()
