Administrator
FB Live Q&A with Pelican Parts Project 993 - 1-4-17 @2pm PST
Happy Holidays Fellow Pelicans ![]() Mark your calendars! We're going to be hosting a FB Live Q&A on Wednesday, January 4, 2017 at 2pm PST featuring our Porsche 993 project. We will have 2 Porsche experts on hand to answer any questions that you may. As seen in the below photos: everything is out of the front end, including the fuel tank, wiring harness, and HVAC suitcase. Post some questions below for us to get the ball rolling... |
I has seen various posts that indicate you can determine (or reset) the code on the 993 Porsche Drive Block system using the ignition key. Is that correct? What is the sequence you need to follow? What are the downsides?
What suspension lowering options are there? What do you feel is the bast?
What's the best thing to do for a leaky AC system?
Administrator
Keep them coming guys!
Once you have used your spare, how do you get it back to the smallest possible size (realizing without a vacuum device it will never be as small as it once was).
How to eliminate radio/ stereo engine noise base on possible bad ground locations.
Anyway to add an iPhone/iPod to the stock radio?
Short of a top end overhaul, what is the best way to fix the Check Engine Light and P1411 error code comes on intermittently even after clearing. May stay off for weeks or come on again in a day or two.
recommended / best parts list for a successful 3.2 build to 3.4 and or 3.5
with Carbs and without |
Administrator
Don't miss our FB Live chat, today at 2pm PST!
Administrator
Thank you to everyone that tuned in - this was just the first one with many more to come on other models If you have any questions, check out our 993 Technical Article Directory
-Dmitry |
Any chance you recorded the event? I ended up getting called into a meeting and got to experience exactly ZERO of your event?
(: mad:
Administrator
https://www.facebook.com/pelicanparts |
