catspaw's Avatar
Max jax owners
Where do you MaxJax owners jack up your cars? I installed my jack, if I reach the rear jacking points, torsion bars, I can't reach the front. What gives?
Tundra
In Heaven the police are Brits, the cars German, the chefs French and the women Italian.In Hell the police are German, the cars French, the chefs Brits and the women Italian
Old 01-07-2017, 07:16 AM
fred cook's Avatar
Max Jax Use..........
Don't the arm inserts slide in and out? Because of the rear weight bias, I keep the rear arms pushed in and extend the front arms. One thing that can affect your setup is the distance between the lifting columns. I set mine at the minimum recommended distance. Don't remember what that was but probably about 110".
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 01-07-2017, 08:04 AM
fred cook's Avatar
Max Jax............
I measured my Max Jax installation today. The verticals are 100" apart measured from inside bottom to inside bottom.
FEC3
Old 01-10-2017, 02:56 PM
I am my 911's PO
'78 SC's Avatar
My posts are 92" apart, measured at the baseplates. This lets me position the car with the center of gravity (jacking sockets) beween the posts and still reach the lifting points by the front wheel wells. I roll the car backward a bit to swing the rear arms past the tires then roll forward. Car is 911SC.
I measured mine post to post and got 100" like Fred.
Old 01-10-2017, 03:49 PM
carreradpt's Avatar
Can you show your lifting points from underneath?
Dan T
'85 Carrera
Dansk premuff/sport muffler
7's and 8's, Steve W chip
Kuehl AC and fresh top end
Old 01-11-2017, 08:01 AM
I am my 911's PO
'78 SC's Avatar
You may choose different locations, but this shows where the arms reach.
Old 01-11-2017, 08:12 AM
carreradpt's Avatar
Don't happen to have a more underneath shot do you?
Dan T
'85 Carrera
Old 01-11-2017, 06:43 PM
ASE Master Tech - 35 yrs
larrym's Avatar
mine are at 105" inside-to-inside edges of baseplates
lifts 914, Civic, Accord, Miata, MGB, Meyers Manx just fine
on initial install i set 'em at 110 - it was too wide for my cars above - so then i measured all the cars to see what would work best
if narrower, like 100 or less, i would not be able to pivot the arms under the miata or manx cuz they'd hit the tires
"... I am German, and if it has no logic it's meaningless."
~ (John le Carré)
911- 914 parts FS: PDF list here - July 2020 https://tinyurl.com/911-9146-914-Parts-FS-07-2020
Old 01-11-2017, 07:41 PM
Turbo Powered Snow Blower
I'm so glad you posted this thread. I'm getting ready to drill the holes and mount mine this weekend. It appears 100" is the magic number.
Derrick
Old 01-11-2017, 07:51 PM
catspaw's Avatar
Diagram supplied by fellow pelicanite.
There's another thread "two-post lift points with pictures" that I found helpful.
Tundra
Old 01-12-2017, 05:21 AM
I spent a lot of time calculating this very issue. It was a challenge as the longer the vehicle the longer the arms need to be. I finally decided on 95 1/2" inside edge of floor flange to inside edge of floor flange.
I can pick up all of my (and my kids) smaller vehicles but i don't use it for the SUV's or full sized pick up.
For the 911 I made custom supports that pick off the torsion tube cover. This makes it very safe to wrench on.
Awesome addition to my garage - absolutely love it. I mounted the power pack permanently on the wall and ran new hoses. The hoses with the kit are crap. I was looking at a larger Bend Pak hoist but i didn't have the height and didn't want to commit the space as my wife parks her X5 on the other side in the winter.
84 911 Targa Carrera currently getting renewed
Old 01-12-2017, 07:12 AM
petercory
My base plates are 104" apart. For my '84 Cab, I have fabricated a set of rear mounts similar to Lake Guy's. In the front, I spread the arms out as far as possible center a 15" Length of 2" X 10" wood over each of the rubber pads and position them between the drains which spreads the load out without damaging the floor.
On my 996 GT3RS and E93 M3 I simply position the arms so that rubber pads align with the factory jacking pads.
In each case I've marked the position for each car on the garage floor. I love the MaxJax, I think that its one of the best investments that I could have made.
Old 01-12-2017, 04:28 PM
larrym's Avatar
Exclamation maxjax custom support
love that custom support - will copy it!
~ (John le Carré)
Old 01-12-2017, 07:24 PM
97" between the inside of the base plates on mine. I also made an adapter for the t-tube, works great.
Old 01-13-2017, 03:05 AM
I know this is an older thread but I would appreciate anyone can share the build plans for the rear custom torsion tube lift pad like pictures above. I’d like to make one, I just installed my MaxJax lift.
Thank you,
Alex
Its easier asking dumb questions than fixing dumb mistakes
1974 Porsche 911 Coupe, RSR Project
1976 Porsche 911 Targa, Black
1986 Porsche 911 Carrera, Black
2006 Porsche Cayenne S, Black
Old 09-16-2020, 06:57 AM
