Source for quality metal drill bits?
Looking for a good source for metal drill bits.
MSC.com or McMasters.com SmileWavy
I buy good stuff from Snap on truck
Norseman Drill Bits 44170 available from Amazon
US made super quality reasonable price. I love these things |
What I've learned from machining and machinists at work, is you don't need really good drill bits, just make sure you use a good tapping fluid.
We drill through SS with jobber bits all the time. |
The term "jobber" has to do with the length of a drill bit. Not the quality.
fastenall has good quality bits that are reasonable.
i do like Hanson hs bits the most, which are on most tool trucks |
I've never gotten anything regrettable from McMaster-Carr.
What are you drilling?
For steel/Aluminum, for the most part I use bits from Harbor freight, buy and index set every couple years. Can but the common sizes in bulk, like 1/8" for pop rivets. Unibit for 'large' holes. Most people tend to drill too fast, and not use enough pressure. The bit should always be making a chip (or curl) When you drill too fast, the bit rides on top and just generates heat(gets dull) Wood, use spade or forstner bits. |
I would never buy from the Snap On truck.....unless somepme else were buying!! |
Sams club
28.00 with steel case |
| All times are GMT -8. The time now is 12:29 AM. |
