Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Porsche 911 Technical Forum
sugarwood's Avatar
Originally Posted by Rawknees'Turbo View Post
The engine cannot be closed on that end as the external crank pulley needs to be there (the drive boss for it is actually the tip of the crankshaft), and it can't be closed on the other end as that is the drive side for the flywheel/gearbox input shaft, etc.
Rawk,
What is the need for the pulley on the outside?
I thought the crank gets spun by the piston/rods.
And the crank is attached to the flywheel.
1986 3.2 911 coupe.
Old 01-18-2017, 03:14 PM
Jeff NJ's Avatar
Originally Posted by sugarwood View Post
Rawk,
The pulley is driven by the crank and with the associated belts, drive the alternator, fan and AC compressor.
1988 930 Venetian Blue
Old 01-18-2017, 03:18 PM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
And on water cooled engines, the water pump, fan clutch, etc. etc., is driven from that end as well (not to mention a large, harmonic balancer in many cases).
As you can imagine, Woody, it's not practical to have all that gear packaged on one end of the engine alone - hence the need for both ends to be open. I'm sure that the overall system balance is better that way, too.
Old 01-18-2017, 03:37 PM
sugarwood's Avatar
Oh, right, the front of the engine needs an exposed pulley (that is driven by the crank) to drive the various belts.
Right, got it. Rear of crank connects to flywheel to move the car, and front connects to external pulley to drive the acc. belts.
1986 3.2 911 coupe.
Old 01-19-2017, 01:40 PM
Flojo's Avatar
THANK you for that pictured writup!
Regards, Flo
79 SC - Frankfurt, Germany
visit me on www.facebook.com/911garage
Old 09-06-2017, 05:47 AM
