Caliper bolts
Hi All,
I'm restoring the rear calipers for my 1971 911T. Unfortunately I could not salvage the bolts that holds the caliper halves together.
There is four bolts on each caliper which two of them are 5 mm shorter.
Searching the web I find that the shorter bolt is discontinued.
90135297813 (long)
90135297812 (short)
So how do you do this the best way? Is there other bolts that is working? Or do I buy the long bolts and shorten them 5 mm?
Thanks for any input,
Jörgen Forssling
SWEDEN
Old 09-06-2017, 02:45 AM
Cairo94507's Avatar
Contact Eric Shea at PMB Performance in Utah. I would bet he can help you out. http://www.pmbperformance.com/catalog.html
'71 914-6 #0372
'17 Macan GTS
Old 09-06-2017, 05:58 AM
Originally Posted by Cairo94507 View Post
Contact Eric Shea at PMB Performance in Utah. I would bet he can help you out. Shop PMB - Catalog
OK! Thanks!
Jörgen
Old 09-06-2017, 06:01 AM
