-   -   Trailing arm bearing and assembly concerns (http://forums.pelicanparts.com/porsche-911-technical-forum/942519-trailing-arm-bearing-assembly-concerns.html)
ppetion 01-15-2017 05:21 PM
Assembling my rear control arm,
new bearings
911 metal control arms
930 axles
930 hubs
After full assembly , I noticed that there is movement if I hold the tire at 6 and 12 o'clock , but no movement at 3 and 9 o'clock .
Axle nuts are tight . Is that normal?
The whole tire moves with the brake disk .
TIA
RD911T 01-15-2017 05:56 PM
That is not normal. Is it happening on both sides?
ppetion 01-15-2017 06:16 PM
Yes happening on both sides
