Its known that the idle adjustment screw doesn't do diddly squat if the main adjustment isn't right. Leave idle adjustment alone, fine tune with that later. Adjust the main rack first, that controls the most amount of fuel. This is the one behind the Allen screw. When you insert screwdriver turn and push very lightly until you feel it insert into the notch, then turn it left. You will feel when it grabs, that's one click, so on and so forth.
RStarga mentioned the Microswitch and is spot on, if it is broken it can cause fuel to shut off when you are coming to a stop sign and not turn it back on at the specific RPM. This happened to my car last summer, disconnect it, then drive it before you go any further. |
If you haven't been following this thread, its worth a look.
http://forums.pelicanparts.com/porsche-911-technical-forum/930796-mfi-lean-coming-off-idle-then-rich-again.html |
Thank you so much for your kind advices.
Your advices are very helpful. I am starting to fix the trouble of my car following the Bosh CMA manual step by step and your suggestions. To fix condition for my car by myself, I’ll love my car more. Regards, |
| All times are GMT -8. The time now is 01:03 AM. |
