BoxsterGT's Avatar
Porsche Crest Chassis Fuel Lines 74 911 ONLY
Finally, I can announce to all who own 74 911s and want to keep them as original as possible and retain their rear pump location: replacement chassis lines up to the pump and from the motor........
Fuel Supply, Tank to Pump-
Fuel return, Motor to Tank-
These are for the 74 model year only, with the latest E-85 rated Hose and Norma hose clamps from Germany. Correct replacements for those owners who wish to retain their rear fuel pump location and vehicle originality.
Please note- I also offer the hi-pressure feed hose from the pump to the accumulator as a separate part.
For more info, please email me. Although I am often up north trying to build a cabin in the woods, I will reply as quickly as possible.
Please, no PMs. Email me only.
Len at Autosportengineering dot com
Old 06-22-2016, 05:34 AM
gearhead
Sweet. I need a set of these.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 06-22-2016, 07:07 AM
Spumato's Avatar
Send a message via AIM to Spumato
How much for the set?
Ryan Russell
(405) 264-6288
Old 06-22-2016, 10:06 AM
THE REDNECK MEXICAN
riverstonefly's Avatar
BoxsterGt I've tried to send pm but your box is full sir lol
Sent from my XT1650 using Tapatalk
Old 01-02-2017, 11:25 PM
THE REDNECK MEXICAN
Pm sent
Old 01-03-2017, 01:07 AM
BoxsterGT's Avatar
Porsche Crest
Good day Jr,
Best way to reach me is by email. Cannot send photos by PM.
Len
Old 01-03-2017, 08:58 AM
THE REDNECK MEXICAN
email sent sir
Jr
Old 01-03-2017, 02:36 PM
THE REDNECK MEXICAN
Leonard,
I've been trying to send you an email but I keep receiving an error on the delivery.
Money order sent via USPS Express and should arrive before 3pm tomorrow sir
Jr
Old 01-20-2017, 02:57 PM
Functionista
manbridge 74's Avatar
A nice piece of kit for those wishing to retain the original configuration.
I must say that my first 74 had periods where it would start hard. Extended cranking etc. Pressure and volume tests were okay. Went through both fuel and ignition systems. After moving the pump to the front crossmember as on the early 911s and post 75 911s I had no more issues. This could've been from today's cruddy fuel, altitude or a combination of both. I'm pro front mount after all that.
Either way you configure it, Len is the go to guy.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 01-20-2017, 04:36 PM
BoxsterGT's Avatar
Porsche Crest
Thank you for the kind words Jeff.
Back then we called it "vapor lock". It was just as you describe. A front pump is a better choice.
Of course, there are some "original" models out there whose owners will not change a thing, even if its an improvement.
The "Hydraulic" tensioners also come to mind.
Len
Old 01-21-2017, 01:10 AM
THE REDNECK MEXICAN
Len
Leonard
I'm trying to email you but now I'm receiving a message error please send me a pm
Jr
Old 01-23-2017, 01:32 PM
