-   -   Reinstalling Cruise Control? (http://forums.pelicanparts.com/porsche-911-technical-forum/942945-reinstalling-cruise-control.html)
vesnyder 01-19-2017 08:05 AM
I resealed my motor last Summer and when I reinstalled the motow I removed/disconnected the cruise control. I am torn trying to determine if I should reinstall. I never used it but I feel it came with the car and I should put it back. It probably saves me about 12 oz of weight! What do you think??
DaveMcKenz 01-19-2017 08:10 AM
If you have all the parts, and they are fully functional, why not? Either the brain, the cable, or the actuator may be faulty, and derail your efforts. I have some highway driving planned, so I just went through this.
Good luck,
Dave
911tracker85 01-19-2017 11:29 AM
I had pulled mine when the cable to the TB broke.
finally decided to put back in. ended up using a guitar string to replace the inside wire of that cable.
dont use much, but nice to have when convenient to use.
GH85Carrera 01-19-2017 01:05 PM
Cruise Control is useless in daily use. It is a wonderful thing on long road trips.
My cruise quit last year. I did all the tests (the manual is wrong for the test procedure by the way) and everything was testing fine except nothing worked. I sent the brain off to be fixed and while looking at the engine I finally noticed the Bowden cable was broken. I had to replace it with a used one since they are not available new at all anymore.
911tracker85 01-20-2017 11:51 AM
that is what I replaced with a guitar string. pulled the inside wire out and slid in the guitar string, think is was an acoustic wound D string. working great.
Kool-aid-82 01-21-2017 08:17 AM
Great tip, now I need to find a guitar store in my area...
911tracker85 01-21-2017 08:28 AM
I just got a full set to replace strings on my guitar for $5.
and I used a little wire clamp on the end at the TB. the stop on the string worked fine for the cruise actuator end.
good luck.
just dropped the car off the lift yesterday after a lot of work, taking for a nice drive today. going to hit 65 and dry.SmileWavy
gazzerr 01-21-2017 07:47 PM
You can still get the cable but you have to order it from Porsche in Germany. Not cheap though. About $200 from memory.
DaveMcKenz 01-21-2017 09:03 PM
The SC cable is available from our host. The 3.2 cable is listed as NLA. Maybe Porsche direct will provide something.
Good luck,
Dave
Chuck.H 01-23-2017 06:42 AM
I live on a curvy road that was built for 55mph but the county commissioners gave in to the bicycle crowd and dropped the speed down to 40mph; local law enforcement loves it for the easy tickets it generates.
How anybody could drive down this road without cruise control is beyond me.
Chuck.H
'89 TurboLookTarga, 426k miles
GH85Carrera 01-23-2017 08:25 AM
Not for the 3.2 system. It is no longer available. If you know of a source, please elaborate. The cable on the SC is different.
DaveMcKenz 01-23-2017 11:33 AM
Hi Glen,
What exactly is the difference in CC cable from SC to 3.2? Could the SC cable be modified to work with a 3.2?
Thanks,
Dave
GH85Carrera 01-23-2017 12:56 PM
I don't know. I don't have a cable for the SC handy. I guess I need to find a buddy with a SC and take a look at them together, side by side.
