Stranger on the Internet
patkeefe's Avatar
CIS Airbox Plastic?
Hi all,
I am repairing some seam leaks in a CIS plastic airbox. From what my research indicates, this plastic is a form of PPS:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&cad=rja&uact=8&sqi=2&ved=0ahUKEwjcweyzgNvQAhUEZCYKHY55BbIQFggiMAI&url=https%3A%2F%2Fen.wikipedia.org%2Fwiki%2FPolyph enylene_sulfide&usg=AFQjCNGCh4syW3eCSswunxLnCtzP_BAvig&sig2=_vyyOGDcbs2SQUjGzS021A&bvm=bv.140496471,bs.2,d.cGw
Evidently, this requires a very special form of adhesive, two of which are Loctite products. Has anyone used these specialized Loctite adhesives, and what kind of results did you have?
My airbox need to be sealed not only for vacuum, but also pressure-turbo application.
TIA
Pat
Patrick E. Keefe
78 SC
Old 12-04-2016, 09:10 AM
El Duderino
tirwin's Avatar
There was a thread a while back where someone investigated what kind of stuff to use. I'm trying to remember anything that would be useful in a search. I don't recall how it ended up.
You doing an EFI install?
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 12-04-2016, 09:34 AM
El Duderino
tirwin's Avatar
I think this was the thread:
Air Box Repair Myth or Reality ??
Old 12-04-2016, 09:36 AM
I'd fab a metal one for turbo app.
206 637 4071
Old 12-04-2016, 09:55 AM
ROW '78 911 Targa
timmy2's Avatar
Pop off valve going to pop on boost?
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 12-04-2016, 09:59 AM
I agree that the airbox is most likely PPS (discussed in this thread):
What to use to repair CIS airbox?
Last time I sealed my CIS airbox I used the Loctite "plastic welder" two-part epoxy. Some discussion of that here:
Sorry - Yet another CIS troubleshooting thread...
The epoxy seal has held up well after a few years; no leaks yet. However, I don't have a turbo application and would be wary of an epoxy-repaired/sealed airbox holding up to pressure (when the epoxy is applied from the outside).
One thought I had was to mask the openings and pour in something like a gas-tank sealant and swirl around the inside to coat all surfaces/seams. I never did pursue this, but it seems that would be a more robust sealing job (especially for something like a turbo application). I'm not sure how to deal with the spray bar for the cold start valve...
Old 12-04-2016, 10:03 AM
patkeefe's Avatar
Yes, I am tired of the CIS. I went with an SDI from Racetech. I am machining parts for the install, and trying to get the airbox I cut up to quit leaking. I may have to break down and buy some of that $50 epoxy.
The other epoxy I tried just essentially laid on the surface. Except for a few pinholes, it didn't leak under 20 PSI in water. But, I could easily lever that layer of epoxy off with an X-Acto knife, so I have my doubts about it's durability. It appears that stuff would work for vacuum only applications...which is likely why there are so many recommendations for epoxies that "work".
I had a Webb airbox, but I sent it off to a fellow Pelican for his use. I can't see cutting up a valuable airbox for this conversion. Those things are rare. If push comes to shove, I will build a new plenum for this application.
Patrick E. Keefe
78 SC
Old 12-04-2016, 10:43 AM
patkeefe's Avatar
Dennis, when I was running the original airbox with the modded BAE kit, I calibrated the pop-off valve in a tub of water. Basically, it was a plumbers test plug. I blew air into the box at 15 PSI to make sure the plug did NOT blow out, then I would give a quick burst of compressed air at 100 PSI to make sure it did. It is hard to simulate a shock wave with compressed air, but I never had any problems with it.
fan, I read your posts prior to this. I see you have also done a bit of looking into this matter. Thanks for your research!
Patrick E. Keefe
78 SC
Old 12-04-2016, 10:49 AM
patkeefe's Avatar
BTW, I don't have the cold start spider in either of my airboxes (a big port and a small port). I did modify the small port box to accept the early SC runners (my car is early SC) by machining some rings from CPVC and gluing them on. IIRC, late box has 1.325" ID openings, and early is 1.500". It is a big difference.
I once sealed a fuel tank with that yellow sealer stuff by pouring it into the inside. It may be fairly tricky to duplicate that effort with an airbox, and I wonder how long that yellow stuff will stay put in swirling pressurized air.
Patrick E. Keefe
78 SC
Old 12-04-2016, 10:54 AM
There are a lot of parts made of various plastics on our Pcars. Are there some tests to establish what kind of plastic a part is made from? Such as shaving off a small amount to see if it softens or dissolves in acetone, or MEK, or alcohol, or ?? Would be helpful to know when dealing with a NLA part that has broken and you need to attempt a repair.
Old 12-05-2016, 10:58 AM
patkeefe's Avatar
I am very reasonably sure it is made from polyphenylene sulfide. I spent an hour or so this morning on the phone with Henkel, MasterBond and one of Henkel's technicians. PPS is quite difficult to bond as in the patching and seam sealing required. They did give me some part numbers of products to apply which should work. I am going to buy a tube of one of them, a single part epoxy which needs to be oven cured, and see how that works out.
Patrick E. Keefe
78 SC
Old 12-05-2016, 11:04 AM
El Duderino
tirwin's Avatar
With EFI conversions gaining popularity, I would like to see someone make a plenum/throttle body that would be a drop-in replacement so people didn't have to cut up air boxes.
Good luck on the turbo application! I'all be interested to see your progress.
Old 12-05-2016, 02:09 PM
ROW '78 911 Targa
timmy2's Avatar
Interesting read here :
78-83 Aluminum air Box
Dennis
Old 12-05-2016, 02:47 PM
patkeefe's Avatar
Dennis that is a really nice aluminum airbox. Generally the first one of anything costs a million dollars, and the price goes down from there.
tirwin, I will see how the repair goes, before I decide to make my own for the EFI application. I'd have to make it from steel, 'cause I can't weld aluminum.
Patrick E. Keefe
78 SC
Old 12-05-2016, 05:43 PM
ROW '78 911 Targa
timmy2's Avatar
Lol, visions of Dr. Evil "one million dollars" pinky finger to lip...
I probably shouldn't have shown that post to Tim knowing how much he likes shiney things...
Dennis
Old 12-05-2016, 08:35 PM
El Duderino
tirwin's Avatar
Dammit, Dennis! You're making my tinkeritis flair up again!
Old 12-05-2016, 08:44 PM
San Diego, CA
I feel pretty fortunate to have one of these metal air boxes on my 77 complete with pop-off valve. Someone more familiar can comment on who made it and how long ago. Its very accurate and high quality from what I can tell.
Old 12-05-2016, 09:41 PM
patkeefe's Avatar
Avanti, that looks like a Webb airbox. They no longer make them.
Patrick E. Keefe
78 SC
Old 12-06-2016, 06:10 AM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Not like the Webb I had on my car, there were a few mfgs in that era.
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 12-06-2016, 10:17 AM
Nux Nux is offline
Nux's Avatar
Don't use epoxy - it will not hold due to the vibrations. Initial test will be fine, but only for a short drive. Also I'm not sure the bond it self will hold gasoline exposure.
Old 12-07-2016, 05:05 AM
