-   -   930 Engine upgrade question (http://forums.pelicanparts.com/porsche-911-technical-forum/943153-930-engine-upgrade-question.html)
prez! 01-21-2017 06:51 AM
I have a question for the 930 guru's. If you add a long neck intercooler and K27 turbo to a stock 86 930 engine what should you expect in added HP ?
Thanks.
dap930 01-21-2017 08:35 AM
Which K27? Any exhaust changes? Post in the Turbocharged/Supercharged forum for lots of opinions.
Rawknees'Turbo 01-21-2017 08:52 AM
An improved intercooler (such as an old school, Garretson, as well as many others) has been proven on dynos to add approximately 25hp.
I can't recall the h/p bump numbers for a k27 7200 (the most common version), but they are significant if you have a free flowing muffler to go along with it (a muffler change alone is worth about 40-45hp).
Keep in mind that you don't get the full benefits of either without using an adjustable WUR so fueling can be tuned.
bkreigsr 01-21-2017 08:58 AM
The K27 will change the throttle response profile.
How much HP it will add depends on the spring you use in the wastegate.
Are you feeling lucky?
Bill K
prez! 01-21-2017 09:59 AM
I was going with a 7200 and Fabspeed's long neck intercooler and custom free flowing sport muffler. Open to any advise if there are other versions of the K27. I appreciate the feedback.
T77911S 01-23-2017 06:02 AM
add raelyl8's header.
I have the borla twin pipe, very nice deep sound. my neighbor, the judge, loves it. when I don't drive the car much he asks where is his alarm clock. I leave at 6am
I have tried the sport, did not like it as much
