3.6 plastic plenum on a 3.2/3.4 DME engine - straightest path
Hi Gentlemen,
I have a 3.4 build this spring and am aware that running the 3.6 plastic plenum in lieu of the stock 3.2 plenum is a good way to go. I know I'll need the 3.2 to 3.6 intake stud adapters (which I know where a set is), but what I don't know is are the plenum, intakes, injectors, rails from the 3.6 used with the 3.2 throttle body and ancillaries? Or can the 3.2 DME operate a complete 3.6 injection system with harness modification? Any advise on the most straight forward path to mating the superior plastic plenum to a 3.2 system is appreciated. All the best, Anna |
Here is a nicely documented build.
RB's 3.2 Hot Rod - Page 5 - Gruppe IB: The Hot Rods - Impact Bumpers |
Give me a year and I'll make you a system using that plastic intake that will blow minds.
| All times are GMT -8. The time now is 02:21 AM. |
