-   -   hand throttle reinstall (http://forums.pelicanparts.com/porsche-911-technical-forum/943449-hand-throttle-reinstall.html)
gptom 01-23-2017 03:06 PM
911T/E/S Carrera RS (1970-73) - Handbrake, Manual throttle, Heating, Actuator
I have forgotten how to re-install the series of washers & hardware for the hand throttle. Does part # 24 flange go toward the center of the car or outside? towards the center, it is hit by the throttle lever. Towards the outside, nut #26 loosens each time the lever is adjusted.
Nut # 26 has a relief on 1 edge. which way is that installed? Also, the slit seems to have closed quite a bit as compared to the one on the heater side
Walter_Middie 01-23-2017 04:27 PM
gptom,
I just went through this on my 1975. The best Pelican thread was this one:
http://forums.pelicanparts.com/porsche-911-technical-forum/639786-hand-throttle-lever.html
I'm not sure if it answers your question, but I remember having trouble with those washers too - the tabs go toward the center if I remember correctly - once they are in the right way, it seems obvious.
75 911s 01-23-2017 04:35 PM
The flange on 24 goes in toward the center and sits under the throttle lever. It acts as the stop to the the throttle down position. So when you pull up on the throttle lever you are pulling away from that flange. The nut is a type of lock nut. The slit portion of the nut is the top.
FunWithPaul 02-02-2017 10:02 AM
If you are interested, I just did a Hand Throttle Repair post in the other post:
http://forums.pelicanparts.com/porsche-911-technical-forum/639786-hand-throttle-lever-6.html#post9457608
