Does Anyone Rent the Door Pin Tool??
I need to remove my doors, and I would like to use the factory-style tool. Does anyone have one of these to rent or lend me?
Old 05-06-2017, 09:23 PM
flyn-hawn's Avatar
I have one but I will not ship it, if you are in San Diego feel free to come pick it up and borrow it
Dave
Follow me on instagram, @flyin.hawaiin
www.davekealoha.com
Old 05-06-2017, 10:21 PM
I'm in LA, that's a bit of a drive... I might just take you up on that though, thanks!
Old 05-06-2017, 10:25 PM
A little lube and a pnuematic chisel will get it out with ease.
Old 05-07-2017, 04:57 AM
If you can't find a factory one, do a search on my username. Last year I used an axle or pitman arm puller set that I was able to rent for free from advanced auto. I don't remember the exact kit but it had a perfect attachment for the included slide hammer to pull the pin.
Ken
1986 930 2016 R1200RS
Old 05-07-2017, 08:08 AM
Ok will do!
Old 05-07-2017, 08:53 PM
Dial 911
A horse with no name's Avatar
Hi...For what it's worth, I found that a larger 'G' clamp did the job for me...The top end of the clamp needs to 'clamp' on to the top outer edge of the pins housing...Once it moves a little you can use a hammer and a punch to knock it out... I did though put several pieces of masking tape on to the top of the housing so as not to scratch it.
Cheers!
“Simplicity is the ultimate sophistication.”
Leonardo Da Vinci
Old 05-07-2017, 09:43 PM
