1987 coupe low mount third brake light
How does the cover come off to change the bulb? I tried pushing on the little knurled centre bit, but it didn't work and I was worried I would break it if not careful. Thanks
Old 01-30-2017, 10:46 AM
Location: Lake View, NY (in the snow belt south of Buffalo)
If memory serves (and it often doesn't) I inserted a flat blade screw driver in the knurled slot and pushed to release the housing. My car is in winter storage otherwise I'd check it out for you. It was actually easy to do. FYI - clean the lens while in there. Someone chime in and correct me if I'm wrong.
Curt
Curt
1987 911 Coupe, Cassis Rot Metallic
Old 01-30-2017, 12:42 PM
Thanks Curt. I will try that at next opportunity
Old 01-30-2017, 05:59 PM
