911, 914-6, 928
Tires for 7"/9" x 16" Fuchs?
Also posted on the 930 forum...
What's the recommended sizes the look and fit the best on a '86 930? Downsizing from some boy-racer 19" to a stock set of Fuchs. No track time is anticipated, just street fun.
I know the stock sizes, and a few alternates, but what is available NOW?
Something the fills the wheelwells with tire without rubbing issues.
Recommendations? Who sell them for the best $$$.
Thanks; Steve
Old 01-25-2017, 07:49 AM
I have a widebody, 7-9x16 euromeisters, went with front 205/55/16, rear 245/45/16, Tires:Bridgestone Potenza RE 11. Got them from tire rack. Car not back together yet but don't anticipate any problems. Fairly standard for turbo/widebody. Good luck, Tim
Old 01-25-2017, 08:14 AM
205/55-16 and 245/45-16 were the original size on the car.
I ran Toyo RA1's and then Bridgestone RE-11's. The Bridgestones are excellent tires and available now. I didn't mind the RA1's, but listening to every little pebble and stone sand blast your car got to be tiresome.
Old 01-25-2017, 08:22 AM
86FlatSix
JQ911's Avatar
I run 225/50 and 245/45 on my 7&9-16s Toyo Proxies TR1s on Carrera flares. Believe this will work on a 930 without rubbing issues
74 BMW 2002 (rust rocket)
86 911 Coupe (weekend warrior)
09 997.2 C2 (semi-daily)
Old 01-27-2017, 12:47 AM
911, 914-6, 928
I see "Performance Plus" shows the Kuhmo XS in 265/45-16 sizes, I thought they were discontinued. Anyone running 265's? I like the slightly taller sidewall look.
https://www.performanceplustire.com/tires-for-sale/kumho-tires/ecsta-xs-ku36/ts:26545-16/
Old 01-27-2017, 09:30 AM
Undocumented User
McLaren-TAG's Avatar
Install 15" then, you're killing the performance on our cars by going with a taller tire.
Old 01-27-2017, 09:45 AM
Senior Member
Jdub's Avatar
I purchased RE-11's through Costco for my 7"/9" Fuchs. 205 front, 245 rear is fine and the 205 will give you a decent light feel without too much interference with the rim lip (roll it anyways).
A 225 on the front makes sense for panels wider than the SC or racers who know the feel and grip they want, but for the street you are just putting a sock down your drawers (hint: it goes in the front).
'78 Targa in Minerva Blue
Old 01-27-2017, 10:29 AM
It's certainly taller than the 245/45R16's that were stock, but at 25.4" diameter, it's a tad smaller than the 315/35R17's (25.7") that I'm currently running on my TurboLook, and would help the OP fill up the wheel wells a little better.
The 315/35's do lower the effective gear ratio a little, but not enough to keep me from starting in second gear which I do normally.
Chuck.H
'89 TurboLookTarga, 426k miles
Old 01-27-2017, 10:40 AM
Fastest Hunk of Junk
Dear lord these threads. Weekly, now.
-Brent
Old 01-27-2017, 11:12 AM
911, 914-6, 928
It's for a 930 so clearance to the lip should not be an issue.
Old 01-27-2017, 11:28 AM
