sean m's Avatar
Becker Radio
All,
Will a Becker Radio from a 2003 Boxster fit in a 77 911S?
Sean M
'77 911S Targa Ice Green
Old 01-30-2017, 03:53 PM
I think that is single DIN size in the Boxster, so should fit in an earlier 911.
Old 01-30-2017, 09:37 PM
My other ride is a C-130J
RNajarian's Avatar
Does that unit require an amplifier? Or is it a stand alone unit?
My 2000 Boxster had the same unit but also had an amplifier in the front trunk. Not sure if it was required for proper function.
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic
2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer
Previously Owned Art from Stuttgart
2000 Boxster -1983 911 SC Cab -1984 944 N/A
Old 01-30-2017, 10:02 PM
911SC Tinkerer
merlinfe's Avatar
CDR23 is a nice unit but it will NOT work without the fiber optic input and output to and from the amp of the car it came in originally.
I tried to make mine work with an optical jumper and even looked at bypassing the optical portion entirely inside the unit to no avail.
The best option is to get a CDR 220 with a screen mod so you can see the screen. You can get this done by Becker USA.
-Steve
-'83 911SC Coupe
SSIs, Dansk GT3, EFI ITB, Instagram: @ Zinnmetallic_sc
Old 01-31-2017, 05:22 AM
911SC Tinkerer
merlinfe's Avatar
Double Post.
-'83 911SC Coupe
Old 01-31-2017, 05:23 AM
