-   -   Sway bar compatibility (http://forums.pelicanparts.com/porsche-911-technical-forum/94441-sway-bar-compatibility.html)
BGCarrera32 01-16-2003 07:16 AM
Hi-
Will the 1987-on 22mm front and 20mm rear sway bars fit an '84 Carrera? Pretty sure the front will but how about the rear (I'm wondering due to the G50 transmission change in '87) Is shape of the rear sway bar different or are they all compatible with the right bushings?
BG
kstylianos 01-16-2003 07:58 AM
BG,
I believe the front 22 will fit, but the rear 20 will not as its a different shape due to the G50 tranny. I was in the same boat you are (82 SC) trying to upgrade sways from a later car.
Look for a rear 20mm sway from an 86 as it also shares our 915 tranny. BTW: its the only year they made the 20mm rear sway that will fit around the 915.
-Charlie
BGCarrera32 01-16-2003 08:12 AM
Thanks much- you probably saved me from buying something that wouldn't fit. Many thanks to you.
-BG
