Stressed Member
Scott Clarke's Avatar
SC trailing arms on early car?
Is it possible to install SC trailing arms on a '70? I know that the sway bar mount is different, but is it just a mater of replacing the hardware, or is the arm casting itself different? Also, I have read conflicting posts concerning the stub axle compatability. Anyone tried this? I know that it would be easier to use arms from '74-'77.
Thanks n avdance,
-Scott
'70 911E short stroke 2.5 MFI. Sold
'56 Cliff May Prefab
Old 01-16-2003, 08:22 AM
nick-moss's Avatar
I have late 80's Carrera arms on my '74, they are a straight bolt on, so if '74 arms fit a '70, then it folows that SC/Carrera will fit too.
The pre 74 arms are fabricated steel, the later ones are cast aluminum.
Nick Moss - RGruppe #318
early911.co.uk
Old 01-16-2003, 08:35 AM
Stressed Member
Nick-
Did you swap out the sway bar mounts?
Old 01-16-2003, 08:38 AM
nick-moss's Avatar
These were fitted on the car when I bought it, but I believe you would have to sort something out for you car
early911.co.uk
Old 01-16-2003, 08:53 AM
Stressed Member
Is your drop link mount (on the arm) the early ball type, or the later bolt type?
Old 01-16-2003, 08:58 AM
nick-moss's Avatar
Bolt
early911.co.uk
Old 01-16-2003, 09:01 AM
Stressed Member
Nick-
Thanks for yur help. One last question: are you using an early type sway bar? I'm wondering if I can mix sway bar components (use my existing bar, and modify the way in which it is attached to the trailing arms).
Old 01-16-2003, 09:36 AM
nick-moss's Avatar
I have a standard 74 bar
early911.co.uk
Old 01-16-2003, 09:37 AM
jluetjen's Avatar
Nick; keep in mind that both your car and the SC have 915 gear boxes. A '70 will have a 911. The reason that this might be an issue is that the half-shafts are different, as well as the stub axles. When I put some '76 arms on my car, I need to replace the stub axles, half-shafts and the output flanges on the gearbox. I basically had to use 915 output flanges and have about 1 mm machined off of the diameter of the bearing surface so that they would fit. The other change is in the shock mounting which can cause the shock body to have clearence problems with the heat exchangers or the tube in the body in which their mounted. Nothing that couldn't be solved with a bigger hammer!
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 01-16-2003, 02:19 PM
