charles
73 911 dist vac puzzle
'73 911 w/ mfi
Dist Vac Puzzle:
I checked timing with both L/R vac lines connected, I get ~TDC (should be ~ 5 ATC)
  • I pull vac line from rt back and put finger over tube and I get 5 ATC
  • I do opposite, leave rt bank connected and pull line from let bank and hold finger over it - I get ~ TDC
  • I run just 1 line (no T) from lt bank to distributor - 5 ATC
I put my 70's era vac gauge on each bank separately and appear to be pulling about same from each ~ 200mm Hg
I sprayed cleaner down both vac ports, and each flowed - so no sign of blockage.
So it appears something wonky with right bank, yet vac gauge seems to indicate it is pulling a vac
Jamie Novak has suggested a vac leak on right side.
Other suggestions, how to test - spray carb cleaner at throttle bodies.
This appears to be a new event - not experience previously, but I know/suspect throttle bodies are leaking.
Charles
Old 02-05-2017, 04:48 PM
rsscotty's Avatar
I assume you are using the factory vacuum tee. I have seen these plugged inside with carbon.
Old 02-05-2017, 05:00 PM
charles
It is not stock T, but it is clear - can see and blow thru it.
Old 02-05-2017, 07:14 PM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
as long as you are getting 5 degrees of vacuum retard you are ok on that front. May be sign of vacuum leak on the other side
Old 02-07-2017, 09:18 AM
