| Registered |  WUR
			What does the plug look like that I need to "knock" on my warm up regulator and where on the wur is it located? ------------------ 82sc | ||
|  10-21-2001, 06:30 AM |
| Registered Join Date: Aug 2000 Location: Roseville,Ca
			It is on the right side of the WUR - you will see about a 1/4" hole in the metal with the plug in the middle. you may have to remove the heater hose to see it.  81'SC
|  10-21-2001, 09:00 AM |
| Registered Join Date: Feb 2001 Location: Tampa Bay Area, FL
			http://www.pelicanparts.com/techarticles/911_warmup_reg/911_warmup_reg.htm ------------------ Michael '78 911SC Euro | ||
|  10-22-2001, 05:23 AM |
| Registered Join Date: Mar 2001 Location: Marysville Wa.
			get ready to knock it in too far and have to do the drill, tap and nut, bolt, washer thing. you'll know you went too far if the engine idle speed surges up and down for a minute or so thru the warmup period.
|  10-22-2001, 07:33 AM |
