LinkBack Thread Tools Rating: Thread Rating: 6 votes, 3.67 average.
Originally Posted by matthewb0051 View Post
That begs the question why pay to powder coat?.. .
Because I'm a crackpot and it was cheap to do. It makes a better base, imho, but what do I know? Very little. I just like the idea of it being on the list of improvements. Powder coated sounds better than painted in my back yard hanging from the swing set, which is fine for the Falcon, but not the Porsche, although I painted the heat exchangers there.
Ken
'69 911E
Old 10-03-2017, 04:53 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #481 (permalink)
Uh oh...
I'm taking apart the front end parts. This looks like big trouble but I'm all in. Got this far, and lost pickle fork. I've seen it, just can't remember where. I was just going to pop this through bolt out, which is one of those bolts where you have to turn the wrench around each click, then it gets to the end, only room for open end wrench that has to be turned around with each nudge.
Remember we were wondering about the little foam tubes. Here's an original. It's supposed to go under the clip.
I'm trying to figure the order of disassembly, once I get the pickle fork to separate the ball joints, looks pretty straight forward.
I was sitting there and just for fun tried to move the black rubber on the chrome strip under the door. It moved easily, I took off the end plates, it slid right off; the other side was frozen, I just pulled it off.
This is what drives me nuts; they put a pop rivet in place of a self-tapping screw, on both ends of the driver's side, but the passenger side was still original.
The strips are not bad for being original
I kind of like this clean look, but then I'ld have to fill all the holes and repaint. It has some kind of rock guard finish, which is pristine. The hole covers came right off, no frozen nuts, and the car was fine too.
Here's where I get in trouble, doing things out of sequence, like taking this apart. I had it apart once, which leads me to believe I can repeat it, but for some reason, the first time, it slid right off.
Ken
'69 911E
Old 10-04-2017, 07:35 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #482 (permalink)
Flojo's Avatar
Rubber stil inside though
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
https://www.instagram.com/spadescustomz_/
https://www.instagram.com/911garage_germany/
https://www.facebook.com/911garage
Old 10-04-2017, 11:12 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #483 (permalink)
I'm looking for advice on how to get the spring plate off the torsion bar, without damaging the bar or the body work. The spring plate looks indestructible. I spent about an hour trying to wiggle it off, pry it off, sprayed silicon lube in there, wiggle wiggle wiggle; nothing. I'm hesitant to grab the bar with vice grips.
The spring plates and bushings are going in the original parts bin and these babies from Tru-6 are going on. Yes, I know I could have gone to adjustable, but I didn't. I'll never race it, and stock is fine by me. When it's all done the suspension on this money-pit will be outstanding.
Ken
'69 911E
Old 10-06-2017, 05:36 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #484 (permalink)
Flojo's Avatar
Originally Posted by kghjr View Post
I'm looking for advice on how to get the spring plate off the torsion bar[/img]
shove it back in place, drill a hole in center of cap, flood it with caramba, get yourself a 3-arm retractor (you call it that?) so you can pull it of while holding pressure in center to block off the bar.
the hole in cap can be plugged later when reinstalled.
Old 10-06-2017, 05:42 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #485 (permalink)
Under the radar
Trackrash's Avatar
Location: Sebastopol, the land of wine and redwoods in The Republic of California.
Remove the dust cap covering the end of the torsion bar. You may have to drill a small hole in it.
Use a couple of 2 x 4s between the torsion arm and the body. Use a large punch to drive the torsion bar out.
Use lots of grease on the spline when re-installing.
Gordon
'71 911 Coupe 3,0L outlawed
Old 10-06-2017, 09:54 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #486 (permalink)
Shaun @ Tru6's Avatar
Ken, triple/quadruple wrap the torsion bar with a heavy shop towel Grab it tightly with vice grips. Heat the end end 1-2 inches of spring plate tube a lot. Hold the vice grip/torsion bar, either grab spring plate blade and pull off or tap the blade (close to the tube) with a hammer. It should come right off. You've got tape in your cover plate hole, put a shop towel in there too.
Tru6 Restoration & Design
Old 10-06-2017, 12:27 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #487 (permalink)
That's what I'm talkin' about. Thank you guys.
Three killer methods.
With Flo's and Shaun's I have to buy stuff vs Trackrash's, I have it all. Drill, 2x4s, large punch, BFH. I'll try it, report back...
Ken
'69 911E
Old 10-06-2017, 02:46 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #488 (permalink)
Look Ma, no spring plates
I went down to pound them out and was having trouble with the right side cap, not noticing the left side cap was missing, or I would have started there.
The cap was being obstinate. I took a break. Thought to spray some of this stuff in the splines. They had been soaking overnight.
Wiggle wiggle, felt a little movement, out they came, both sides
The old bushings were fairly new and did not need replacing, which I find out after I bought new ones and too late to return. Anyone need new spring plate bushings? New, never used, from Pelican, free, pay shipping.
Got my angle marked
This is way beyond my first impulse to just wipe all the grease off. It's a ***** being OCD
Procrastinating the application of undercoating. I need to make a mini paint booth under there with an arm hole. Stick my hand in there with a rattle can and spray away, let the overspray settle, see what happened. Repeat.
Ken
'69 911E
Old 10-07-2017, 12:26 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #489 (permalink)
These new spring plates will look good with the refinished trailing arms and calipers and dust covers and new lines all over the place.
Ken
'69 911E
Old 10-07-2017, 12:29 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #490 (permalink)
78-911SC's Avatar
Ken I'm in for your bushings. Please pm me your paypal info.
PJ
78 911sc Targa
70 911T
Old 10-07-2017, 01:26 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #491 (permalink)
PM sent
Ken
'69 911E
Old 10-07-2017, 02:57 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #492 (permalink)
Undercoating
First phase, taping. The fuel and brake lines are coming off, the transmission mount bushings come off.
I'm going with black, not tan.
Ken
'69 911E
Old 10-08-2017, 06:07 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #493 (permalink)
Ubi bene ibi patria
Hawkeye's-911T's Avatar
Which leads me to believe I am in good company. I've been following your thread with interest Ken. Good luck & full speed ahead.
Cheers
JB
“Two possibilities exist: either we are alone in the Universe or we are not - both are equally terrifying” ― Arthur C. Clarke
Old 10-08-2017, 07:59 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #494 (permalink)
Flojo's Avatar
What about these rust spots under the inner bushings?
Passenger side
Driver side
This need quite some rust-prime application and some welding.
Experts may chime in how to do it.
Old 10-08-2017, 08:20 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #495 (permalink)
outa control
I just wanted to wipe the oil off.
There's nothing left (for me) to take off. Here's where I want a car barn with a rotisserie.
Back yard paint shop is open
Ken
'69 911E
Old 10-08-2017, 06:14 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #496 (permalink)
Cheers
JB
Thanks for the encouragement. This forum made a huge difference in the completely insane decisions I am making and seem unable to stop making them. I am so far out of my comfort level that it defies logic.
My welder is coming by to take a look this week. I'll soak it in naval jelly for a few days.
On the passenger side one, there was a debris field still in there. I vacuumed it out. The bushings came right out with no resistance.
Ken
'69 911E
Old 10-09-2017, 06:50 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #497 (permalink)
Flojo's Avatar
obviously the bushings have benn exchanged not so long ago.
but whoever did this, did a "bad" job in not rust-safekeeping that area.
when done welding the ring, spray the tube with Mike Sanders before reinserting the torsion bars.
Old 10-09-2017, 11:13 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #498 (permalink)
Brain damaged?
I must have been dropped on my head as a baby to come up with these hair-brained schemes. My idea to control over-spray, a reverse paint booth
This is ¾th done, still need some Playtex gloves taped to clear plastic to close the gap between the cardboard and paper to make a containment chamber. I'll have to wait for warm weather to open the garage door to get a little ventilation, outside the chamber of death.
New on the bottom, old on top, not much difference
More new brake lines, next to some old ones
I just hope I can get it all back together and working
Ken
'69 911E
Old 10-09-2017, 11:25 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #499 (permalink)
Porschaman's Avatar
Amazing Post
Ken, fantastic post, so interesting to see parts of these cars I'd never see otherwise. Also great to see so many very helpful responses.
'76 912E (gone but not forgotten)
'82 911 SC (Restored and happy)
Old 10-11-2017, 06:43 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #500 (permalink)
