-   -   Motor overhaul and update with Sleepers Speed Shop (ITB's, AEM, etc) (http://forums.pelicanparts.com/porsche-911-technical-forum/945555-motor-overhaul-update-sleepers-speed-shop-itbs-aem-etc.html)
911 jared 09-07-2017 01:37 PM
yeah i guess your off to a good start...
not bad.
Ryan H 11-15-2017 01:43 PM
Originally Posted by BE911SC (Post 9729062)
Any updates? Saw this thread in the recent Pelican email.
Finally some updates. The last couple months have been crazy at the office and at home. Work, travel, kids sports, etc.
There's actually been quite a bit going with the car, but very sporadic and out of order.
The car is finally with my good friend Willy who's an amazing painter. He can do custom stuff and full restorations. I honestly cant say enough good things about the guy.
It's now completely gutted.
http://forums.pelicanparts.com/uploa...1510785531.jpg
The engine compartment has been stripped. Danny at Sleeper's welded in Tarrett shock tower reinforcements, as we'll be running coilovers.
http://forums.pelicanparts.com/uploa...1510785690.jpg
The sunroof was bugging me, and all that garbage weighs a bunch, so we we plugged it.
http://forums.pelicanparts.com/uploa...1510785723.jpg
Reiver 11-15-2017 02:29 PM
I really like to see young guys working on aircooled 911's...lots of the old guys are or have retired...
Those bearings look good...how many miles on the lump? 3.0's have a deserved bottom end longevity rep.
I'd delete my sunroof in a NY minute too.....
Ryan H 11-15-2017 02:38 PM
Only about 120k.
Reiver 11-15-2017 02:47 PM
Originally Posted by Ryan H (Post 9816151)
Only about 120k.
...sat for a bit....I'm told more studs are found broken on low mileage cars...many driven short distances and never properly warmed up.
My 930-16 had good bearings at 230K when I traded it out for a 930-10.
Was that tig or mig on the sunroof delete? That looks like it came out without any warping.
Flojo 11-16-2017 05:16 AM
Originally Posted by Ryan H (Post 9509777)
...and we assemble a badass 3.0!
I already envy you SmileWavy
Ryan H 11-16-2017 07:17 AM
Mig welded.
My buddy tore his 3.0 down a couple months ago with 210k and the bearings were fine too. It's crazy.
Reiver 11-16-2017 07:37 AM
Originally Posted by Ryan H (Post 9816787)
Mig welded.
Nice welding job....I really want to delete that whole weighty thing...did you weigh all of the mechanism btw?
As to the bottom end that is crazy good.
75 911s 11-16-2017 10:25 AM
Maybe this will help Reiver
I came up with about 33lbs on my semi accurate scale when I weighed the entire cassette, motor, rails, pretty much everything from the sunroof.
http://forums.pelicanparts.com/uploa...1510860281.jpg
KTL 11-17-2017 09:11 AM
Ryan,
Make sure to have the shock tower/bridge member welded at the corners where it meets the unibody structure. You need to beef up that joint with plate steel because it wants to pull away from the longitudinal structure. Right now you're only reinforcing the top of the damper "tubes" with those Tarett gussets, which basically prevent the coilover from punching through.
This link has some good info in it and notice the link in my post where BarryJB shared some good pictures of the damage that coilovers can do to the bridge member.
http://forums.pelicanparts.com/porsche-911-technical-forum/794363-rear-shock-tower-reinforcement.html#post7886086
Reiver 11-17-2017 09:13 AM
Thanks....that is 33 lbs I'd like to see go to weight watchers...especially up high like that.
Ryan H 11-17-2017 10:02 AM
Originally Posted by KTL (Post 9818187)
Ryan,
Thanks and will do!
Fabspeed Motorsport 11-17-2017 01:48 PM
Coming along nicely Ryan!
Ryan H 11-17-2017 02:29 PM
Thanks! It's getting fun again after a bit of a layoff.
Quick update. I sent the cylinders to Gary at Torque Power Engines to have them checked and honed. Good to go!
http://forums.pelicanparts.com/uploa...1510961339.jpg
Ryan H 11-20-2017 11:34 AM
More progress...
Interior almost completely stripped
http://forums.pelicanparts.com/uploa...1511209908.jpg
Pedal set will get restored
http://forums.pelicanparts.com/uploa...1511209942.jpg
Gas tank out and most of the odds n ends gone. Plan to run a battery in the smugglers box
http://forums.pelicanparts.com/uploa...1511209993.jpg
Details...
http://forums.pelicanparts.com/uploa...1511210018.jpg
Ditching everything. 2100lbs or bust
http://forums.pelicanparts.com/uploa...1511210055.jpg
Ryan H 11-27-2017 08:30 AM
Pretty much a bare shell as of today
http://forums.pelicanparts.com/uploa...1511803847.jpg
Ryan H 12-08-2017 12:40 PM
This was fun..
http://forums.pelicanparts.com/uploa...1512769208.jpg
mikl911 12-08-2017 12:43 PM
Brave soul.
KTL 12-08-2017 01:18 PM
The amount of wiring is shocking, isn’t it?
Please don’t throw that away. There’s a lot of useful plugs and terminals and other stuff people can use
senna21 12-08-2017 03:38 PM
Just because you can, doesn't mean you should. Reliability and performance go hand in hand and in that order.
Ryan H 01-24-2018 12:50 PM
Lots of progress the last couple weeks!
Found some cancer/bondo that is getting addressed
http://forums.pelicanparts.com/uploa...1516830454.jpg
Door being stripped. Dark spot is a small dent that's being worked over.
http://forums.pelicanparts.com/uploa...1516830513.jpg
Other door was hit at some point and there's some bondo that's getting addresssed
http://forums.pelicanparts.com/uploa...1516830563.jpg
Pic says it all. We're taking the entire car down to mare metal.
http://forums.pelicanparts.com/uploa...1516830596.JPG
Engine build starts soon!
Ryan H 01-24-2018 12:53 PM
Also deleting the goofy 911 mirrors!
http://forums.pelicanparts.com/uploa...1516830789.jpg
Ryan H 01-25-2018 11:58 AM
All cleaned up!
http://forums.pelicanparts.com/uploa...1516913898.JPG
http://forums.pelicanparts.com/uploa...1516913898.jpg
Ryan H 02-03-2018 03:23 PM
How good is Mark!!
http://forums.pelicanparts.com/uploa...1517703806.jpg
http://forums.pelicanparts.com/uploa...1517703824.jpg
Ryan H 02-20-2018 12:35 PM
We're basically down to bare metal and after all this work I feel like we'd be crazy to not go with a custom color. I saw this years ago and always loved.
http://forums.pelicanparts.com/uploa...1519162498.JPG
Let me know if you have any suggestions. I also like the Tundra Pro cement color.
sithot 02-20-2018 01:40 PM
Jeep Willys, Stone Gray and Fashion Gray
http://forums.pelicanparts.com/uploa...1519166402.jpg
http://forums.pelicanparts.com/uploa...1519166415.jpg
http://forums.pelicanparts.com/uploa...1519166431.jpg
Tremelune 02-20-2018 04:15 PM
I've always loved that olive car. It says "drive me."
3literpwr 02-20-2018 05:59 PM
This is a killer color. I'm trying to decide if i'll keep my rally car rosewood or go olive. The factory olive from the 70's has way more yellow, but still rad.
Ryan H 06-18-2018 12:24 PM
Haven't posted in a bit, but there has been a bunch of progress!
Here you can see the exterior is fully stripped and the vehicle really isnt too bad. Any visible cancer was repaired.
http://forums.pelicanparts.com/uploa...1529353286.jpg
http://forums.pelicanparts.com/uploa...1529353364.jpg
The interior, frunk and engine bay were going to be very tough so instead of stripping them by hand we had the entire car sand blasted....
Ryan H 06-18-2018 02:03 PM
Back from blasting!
http://forums.pelicanparts.com/uploa...1529359208.jpg
Found a couple additional cancer spots that will be addressed.
Looking good!
http://forums.pelicanparts.com/uploa...1529359367.jpg
emptyo 06-18-2018 02:51 PM
So much for a little engine refresh. :)
Ryan H 06-18-2018 02:55 PM
story of my life...
This is now our SEMA booth car so it has to be a home run.
yelcab1 06-18-2018 03:01 PM
you will find sand in that car 10 years from now....
chrisbalich 06-19-2018 06:54 AM
http://i0.kym-cdn.com/photos/images/...53/279/e31.jpg
pampadori 06-19-2018 01:16 PM
Gonna be a pretty sweet Sema build from the looks of it!
Funny that Eibach is using an SC. you know, because of the whole torsion bar thing.
Trakrat 06-19-2018 01:53 PM
Originally Posted by Ryan H (Post 10077786)
wow... look at ALL THAT SAND accumulating in the corners. That's going to be a mess to clean up...
Ryan H 06-19-2018 01:58 PM
cough coilover cough
:D
'76 911S 3.0 06-19-2018 03:12 PM
:D
http://forums.pelicanparts.com/uploa...1529449970.jpg
Ryan H 06-25-2018 07:35 AM
Working on some custom CF dash parts
http://forums.pelicanparts.com/uploa...1529940899.jpg
'76 911S 3.0 06-25-2018 08:59 AM
http://forums.pelicanparts.com/uploa...1529945957.jpg
Looks fantastic!
Copyright 2020 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
