Batteries
There seems to something missing, like a battery and a positive cable. Secondary battery? My shop manuals are not here yet.
What about this battery? This looks completely bogus.
While I'm at it, this surface rust will be addressed
Ken
'69 911E
Old 02-06-2017, 08:12 AM
Your 911 originally had 2 batteries. It has been coverted to a single battery and, in your case, a light weight battery. This is common. The "search" function will provide you with more information than you likely need or want.
Ass-engine Nazi slot car -- PJ O'Rourke
Old 02-06-2017, 08:21 AM
On second look, make sure those cables on the passenger side are not running to anything.
Old 02-06-2017, 08:23 AM
+1 on this^^.
The cable in your photo is the positive cable, and it would connect to to the positive cable on the driver's side, unless it has been isolated. The stud shown above the box is for the ground cable. The early cars used two 12 volt batteries wired in parallel, but many have converted to a single, more powerful, 12 volt battery as replacing the early ones can be extremely expensive.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 02-06-2017, 08:43 AM
Vintage Owner
Jack Stands's Avatar
Your previous owner switched from the original two battery set-up to a single Braid battery ( which is supposed to be an excellent battery). However, a good friend of mine has kept the original two battery set-up and has had great luck with them using a battery maintainer in the winter storage season. If it's working, leave it be till theaters needs replacement then decide which way you want to proceed. Supposedly the dual battery system was designed with weight distribution in mind. Another option is to move the battery into the 'smugglers box' if your car is not air conditioned.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 02-06-2017, 09:05 AM
Thanks for all the answers. This forum is awesome. It failed emissions, have appointment with Storz. We are going to address the list. Supposedly it needs a clutch.
Ken
'69 911E
Old 02-06-2017, 12:35 PM
80-911SC's Avatar
The two batteries like others said had weight distributing in mind ....
You may be better suited to use the passenger side as far as weight goes ....
The "custom install w the wood wedges ... that would drive me nuts ...
Old 02-06-2017, 07:24 PM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
The two battery system solved a problem Porsche encountered during high cross winds. Earlier models had lead weights there to solve the problem. My advice is don't think you are smarter than Porsche engineers, put the two batteries back.
Chris
73 911 E
Old 02-07-2017, 09:11 AM
Cool
May hold true, unless your current girl has had too many tortillas....
Old 02-07-2017, 09:21 AM
Miata batteries
Chris
73 911 E
I agree. I have 2 Miata size batteries in my 1973 and they put weight where it belongs and last a loooong time.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 02-07-2017, 12:06 PM
The consensus seems to be along the lines I have been thinking. In this case, put it back like it's supposed to be.
Ken
'69 911E
Old 02-07-2017, 01:30 PM
It's a start...
Ken
'69 911E
Old 02-08-2017, 10:57 PM
Bob says leave it alone. Its been working fine like this. If it ain't broke, don't fix it. I'm not competing in concourse events. It's down on the list, like for the next owner.
Ken
'69 911E
Old 02-11-2017, 06:22 PM
