PMO Carb Float Level Adjustment Advice Needed
Anyone with PMO's care to give a brief float level adjustment lesson? The instructions that came with the carbs are a bit thin and I'd like to hear from someone who's been there done that. Note that these are not Webers and the procedure is different with the PMO carbs. Thanks to all.
news to me... interesting
Well, that was my thinking too. When I installed the carbs a while back, I talked with Rich at PMO since the float levels were not equal. He suggested that I wait a bit for the needle valves to completely seat and then if the levels still needed adjusting to follow the procedure listed in the PMO kit. I specifically asked him about washers/shims under the needle valve and he said that's not how it's done on the PMOs. It involves bending the little metal tab on the float according to the instructions. Now this seems a bit odd to me since the PMOs are an amazing piece of mechanical art and everything about them is very nice. Before I call Rich back on the phone I was hoping someone with some PMO experience could clear up some of my confusion about setting the float level.
I haven't seen the insides of a PMO carb, but as described, it sounds like the float is adjusted like most any other carb with the float/seat in the top housing. Rest it upside down, then measure/adjust the distance between the gasket surface and a reference point on the float by bending the metal tang that contacts the needle.
I don't know, but since the PMOs have an inspection window to verify fuel level, is there any way to fine tune it w/o taking it apart? Didn't the PMOs come with any instruction manual? Sherwood Lee http://members.rennlist.org/911pcars |
The ONLY thing I fould lacking when I bought the PMOs was the documentation. The carbs are beautiful but the instructions were....thin. There are about 20 photocopied pages that come with the kit describing the conversion process from CIS to PMO including the set up procedure. There is a single page on the float arangement and how to measure what to where and the tab to bend. Suffice it to say, I think they feel that if you are putting these carbs on your car you have a fairly healthy working knowledge of the Webers they replace. I have several books on Webers and have used them in conjunction with PMO's pages to set up and dial in the carbs. The fine tuning of the float levels is one thing I haven't attempted to date since it's running "almost" perfect and haven't felt the need to take the carbs apart to bend the tab. Just seems a bit tedious to take them apart and bend the tab, then put them back together and see if the level is correct. I keep thinking there must be an easier way (i.e. the washers) to do this.
One more carb question while people are interested...
When I turn on the ignition key and energize the fuel pump, the sight glass for the fuel levels just fill right up to the top. Is this normal? The fuel pressure is 3.5 PSI (at least that's what the fuel pressure gauge that came in the kit says...I have my doubts as to its accuracy). Shouldn't the floats shut off the flow of fuel when the correct level is reached?
"The carbs are beautiful but the instructions were....thin."
When PMO was engineering prototypes, I spoke with Richard about providing documentation/service procedures for the new carb (that's what I do); even went as far as visiting the molding/casting facility where the prototype parts were being made. Nothing came of it; maybe didn't press him hard enough, although I'd have to admit that documentation funds are always scarce after spending a bunch on engineering, casting/machining and sourcing parts for this unit. Oh well. I guess most techs find this unit similar enough to regular carbs. Still, an external float adjustment would be a definite plus. If I had to R&R the tops of my Webers to fine tune the float level, I'd be one unhappy tuner. Isn't there any sort of threaded valve seat arrangement on the carb to adjust the fuel level? Sherwood |
Thanks Ron. That's one thing I wasn't too sure about. I assumed that coming from PMO the floats would have been set. I suppose that was a combination of wishfull thinking on my part and a desire not to open up the new carbs and f... things up inside before I even got them installed.
Here's the PMO instructions
1 Attachment(s)
Here's my poor man's scan of the float level instructions...
1 Attachment(s)
Sherwood...as far as i can tell there is no way to get at the float valve/seat....You can see from the photos that the access points that exist on the Weber are not present.
1 Attachment(s)
Other side....
in days of old when. . . even if the carb has been thrown around from going from one friend to another I would check the floats and PMO is a continuous class act.. obviously your 911 is a class act, or you would not be going thru this now.. so from one perfectionists to another.. I will be installing a 2 micron fuel filter.. I believe the routine is 10 microns.. and the aids virus is 3 microns, I think, LOL..................Ron |
I'm running a Racor 110A fuel filter water separator (10 micron?) but have been contemplating some additional filtration just before the carbs. Where did you find a 2 micron filter?
Gratuitious picture :)
1 Attachment(s)
Thanks Ron
I thought it might be a 2 micron but I couldn't locate the specs online. Got the floats adjusted as per the PMO instructions - bending tabs and whatnot. Still not perfect but close. The float bowls still fill all the way up when I energize the fuel pump but settle back down with the car running. Normal??
I am now looking for the cause of a intermittant miss from 3000 RPM up. Not sure if it's carb/jetting related or my ignition. Feels like an ignition issue but the ignition is fairly new and the wires/plugs/cap/rotor are all new as well. Sometimes it cuts out sometimes it doesn't. Happens more as the engine warms up. Could this be caused by the float levels still being off slightly? Thanks |
Re: Thanks Ron
and our electrical pope once mentioned that the Beru plug connectors can sometimes miss at higher heat than warm-up heat only.. which sounds like fun to find when testing room temp wires w/an ohm meter.. how about a timing lite rotated from wire to wire when this is happening.. I hate those Beru connectors.. I also use a vacuum machine that picks up ultrasonics from vac and exhaust leaks.. it works great. I've seen the same unit in Snap-On and other brands.. costs $75-$200 for the same unit... |
Well....first thing I did was swap ignition cables with a set of MSD wires I built fron scratch with MSD plug connectors. No difference - same intermittant cut 3K RPM +. The ignition box worked 4.0 with the CIS before the PMO conversion so I'm hesitant to believe it's bad after only about 1K miles. The problem first arose after the carb conversion. So that's where I'm at. I've reset the float levels pretty close, cleaned the idle jets/passages several times, changed the plugs for a little hotter set (BP6ES), swapped ignition cables, checked cap and rotor for obvious damage. I haven't checked the coil as it is also new with the carb conversion. I have another laying around so I'll give that a whirl.
Could a piece of dirt intermittantly clogging a main jet cause a cut at higher RPM? It seems to feel like more than one cylinder being affected however. One other piece of the puzzle - #2 requires several turns more on the air bypass screw than any other cylinder to achieve the same balance. This is also the cylinder with the vacuum port for the brake booster. Smell anything funny here? I'll give your 3K to WOT thing a shot and see if it sheds any light. Thanks again for the insight. |
| All times are GMT -8. The time now is 07:21 AM. |
