blur911's Avatar
Originally Posted by DRACO A5OG View Post
Did you use a jig prior to torqueing down the pinion?
Since I'm asking "what jig?", I guess not.
I held the input shaft with a tool, locked it in a gear and used a torque wrench. Basically following Pete Zimmerman's how-to series.
Old 05-16-2018, 03:13 PM
Member 911 Anonymous
DRACO A5OG's Avatar
jig
This jig:
Use this then button the bracket down and torque the pinion and shaft nuts to insure everything lines up and rotates without binding. Once all lines up remove and place case and test again.
'85 Carrera Targa
PCA/POC
Old 05-16-2018, 07:08 PM
blur911's Avatar
Yeah, I don't have that jig, I just installed the center section and snugged it up. Everything was moving freely until I tightened the pinion nut.
I did put new 4-point bearings in and of course new 1st and 2nd synchros. Differential didn't come out and same pinion so I re-used the same shim behind the retainer.
Old 05-17-2018, 05:15 AM
blur911's Avatar
Does anyone have a CNC file or a drawing of that jig so I can make myself one?
My mechanic friend looked at it last night and said he thinks the pinion shaft is a little stiff, but he'd use it as is.
Is there a spec for torque needed to rotate the shafts?
I tried loosening the nut, shaft turns freely, well, maybe 20lb/in (torque wrench starts at 25lb/in), if I start torquing down the nut I get to about 50lb/ft and my baby torque wrench says it now takes 35lb/in to turn. Torqued down to spec it is about 50lb/in to turn the transmission over from the pinion nut.
Is this too much?
The only thing I can think of that could cause would be squeezing the two inner-races of the 4-point bearing with too little clearance in the bearing.
Old 05-18-2018, 05:58 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Send a message via Yahoo to KTL
Did you give the bearings a light coating of gear oil? If they’re dry, they would tighten up a bit when you torque the nut. The whole shaft assembly is a long stack of parts that is squished together when you torque the nuts that are staked to the shafts
Kevin L
Present: '86 Carrera, '79 911SC widebody conversion rolling racecar shell
Past: '87 Carrera
Old 05-19-2018, 07:40 AM
Great thread... I am currently dealing with my 915 with LSD which was just rebuild by a retired Porsche specialist.. When I got the box back, noted that it was imposible to turn the drive shafts while in gear, but that the input shaft could be turned. They assured me it was just tight so to install and drive. Well I did that but it whines its head off, and binds up in reverse, stalling the car. It needs lots of revs to reverse. I did buy a CMS 1 piece plate to be used. Someone suggested that if the nuts that bolt on the bearing retainer plate are too large diameter, than can squeeze the plate inwards, which would deform the 'hole" and deform the bearing.. we are only talking tiny amounts, but maybe enough to bind the shafts...
Thoughts?
Old 01-01-2019, 05:11 PM
blur911's Avatar
Thoughts?
If they used stock sized nuts and washers it shouldn't be the problem, there are flat machined surfaces for the nuts to sit on, if they were too large it would interfere and I think be quite noticeable when assembling. Not to say this didn't happen though.
I do have a similar problem as you do with my other transmission, if I tighten up the plates it gets very hard to turn, this led me to discover that the holes the bearings sit in are no longer quite right. One of the outer races must have spun and screwed it up (why we use 1-piece retainers now) and it now needs machining and sleeving. I never installed it so don't know if the symptoms would be the same as yours.
Perhaps your pinion is too tight, needs a thicker shim?
Old 01-07-2019, 05:59 AM
gearhead
No. The bearing plate isn’t your problem. Sounds like they set the ring and pinion too tight.
1974 911 Restorod
1974 914 Bumble Bee
1975 911S Tom's Targa
2008 Cayman S Mule
Old 01-07-2019, 09:45 AM
