-   -   engine power seems lacking at midrange (http://forums.pelicanparts.com/porsche-911-technical-forum/945697-engine-power-seems-lacking-midrange.html)
Trakrat 02-12-2017 07:29 AM
forgive my random writing... as I tend to think as I type.
First off... did a search on here for a similar issue and found some posts that seem to point to replacing the coil (unfortunately I'm not sure what this 'coil' is?)
I'm not familiar with what part is what... or what to even try replacing. As far as I know, everything is still original on my engine.
The issue is that at about 3000-5500 rpms, the car tends to lack power in the midrange.
When it hits over 5000rpm... it picks back up and starts gaining power again.
car always starts up great...idle is perfect... engine sounds fine (no coughing and no odd sounds).
The car doesn't actually lose power, nothing drops or anything that would be a concern. It's just that the car seems to pull slower through the midrange with WOT.
So... given I am new to my car and not familiar with what a car like this feels like when it is in perfect condition...
Is there a recommended gear, speed to test hard pulls in this car to see how it performs?
Is there a timed pull I can try? (ex. how fast should it accelerate from 40-60mph in 2nd gear? or 3rd gear?)
To me, and my experience, it seems as if the engine isn't 'opening' all the way when on WOT.
Any suggestions on what to replace first? New spark plugs? new plug wires? etc...
stlrj 02-12-2017 10:31 AM
Try another air flow meter. I've tried several on my 87 and I can tell you none of them are created equal performance wise. If you happen to get a good one, you'll be smiling from ear to ear.
Cheers,
Joe
87 Carrera (and smiling from ear to ear)
strictly 02-12-2017 10:31 AM
i would normally say lack of power is fuel related, when you can hear the engine "gasp" as you rev it, but i think in your case it could very well be ignition as is your hunch, possiable air leak too.
I say don't replace anything willy nilly - diagnose it. You can check your spark plugs wires, coil, and rotor with a multimeter for resistance, start with that. You should also be able to check the air flow meter, buy a multimeter and get a porsche workshop manual, and systematically check. Normally the fault finding sequeance for any engine is
Step 1 - Verify/Check compression/leak down test
Step 2 - Check Igntion System
Step 3 - Check fuel system (i.e carbs, injection)
I always follow these steps, it works, and you will learn about your engine and verify its state of health as you do so.
McLaren-TAG 02-12-2017 12:59 PM
The wrong muffler "upgrade" will do exactly what you're describing. You said you're new to the car and the engine is stock but is the exhaust?
A 3.2 is at its glorious best pulling hard from 3 to 5k
stlrj 02-12-2017 01:38 PM
A 3.2 is at it's glorious best pulling hard from 3 to 5k
Even more glorious when it pulls from idle like a 996.
Cheers,
Joe
Trakrat 02-12-2017 01:48 PM
[QUOTE=McLaren-TAG;9470771]The wrong muffler "upgrade" will do exactly what you're describing. You said you're new to the car and the engine is stock but is the exhaust?
A 3.2 is at it's glorious best pulling hard from 3 to 5k[/QUOTE
That's exactly what I've understood the 3.2 to be strongest at... that's why I am guessing something isn't quite right. Maybe poor performing injectors?
yes... it's a stock exhaust... and original I'm sure based on the rustiness of it.
I plan on replacing the exhaust with a fabspeed catless 2 out design.
I was also thinking of going with some better performing spark plugs and magnacore plug wires and whatever other go fast parts I can put on it (including a chip)
My biggest problem (and I'm sure many of you can relate)... is that I want to do EVERYTHING NOW!!! But I need to go at this one step at a time.. fixing one thing before moving onto the next thing.
McLaren-TAG 02-12-2017 01:51 PM
Cheers,
Joe
I guess, maybe the PO should sell his 87 3.2 and buy two or three 996s with the money. ;)
stlrj 02-12-2017 03:13 PM
He could or another alternative, incorporate some of the tricks the 996 uses, like EV6 injectors and optimized fuel delivery and ignition. A much better option than dealing with IMS issues, you think?
Cheers,
Joe
Retro 02-12-2017 09:28 PM
Get a Steve Wong chip.
stlrj 03-05-2017 04:32 AM
The problem with replacing the chip is that it only masks the underlying issue and does not deal with the problem. I have a stock chip in my 87 and have four air flow meters that behave very differently. The one I'm currently using that I have modified makes my Carrera pull like a freight train right off the line with loads of throttle response at all rpms. I also have an air flow meter that makes it fall flat on it's face that no amount of chipping will ever fix.
I feel that chipping is like a band aid and never deals with the real issue.
Cheers,
Joe
bickyd 03-05-2017 07:59 AM
chipping is bad if it is used to mask problems but a properly running car can benefit greatly by chipping. Scarceller on this site is offering a chip and injector deal that i feel is an immense improvement on our cars. four hole modern injectors with a dme overhaul and a fresh modern mapped chip. i am doing this in about a month when I can actually drive where i am. he also sells a mass air flow system that is cool but i want to retain the stock look of the air flow meter. I carefully took my air flow meter apart and reindexed the wiper arm on the wear strip and it removed the midrange stumble completely. just my opinion, take what you will. Dan.
stlrj 03-05-2017 10:23 AM
I've been using the much improved four hole Bosch EV6 injectors but find the five hole GM low impedance Multec injectors are even better performing and smoother. I also found that increasing the spring tension while reindexing the wiper made a huge difference on the AFM. Joe
bickyd 03-08-2017 10:10 PM
stlrj. are the multec injectors ev6 connections also. if so then they require the ev1 adapter? would you have the part number of the multec injedtor please so I can compare at the Weiss injector site. thank you. Dan.
stlrj 03-10-2017 12:28 AM
No adapters needed on any of these multecs. Right now I'm running high impedance multec six hole (Saturn) injectors, PN 17109448, with great results since they atomize the fuel even better (unable to find flow rates on Weiss site). For best results it's recommended that plug gaps be increased to 0.060" to avoid an intermittent miss.
Cheers,
Joe
bickyd 03-10-2017 01:05 AM
Thank you very much Joe. Are you not worried about a lean or overly rich condition? Do you have an afr guage installed? I am very conscious of the cost to rebuild but people seem to try new injectors on the fly. Can the wrong injector be catastrophic? I do not know but I do know I want the benefit of modern injector drivability. Thank you again. Dan.
Sent from my SM-G903W using Tapatalk
sp_cs 03-10-2017 01:53 AM
Get it on a dyno to obtain a baseline power/torque/AFR reading
bickyd 03-10-2017 07:20 AM
problem is.... where I live the nearest dyno is six hours away. i will buy an afr guage I guess. thank you.
stlrj 03-10-2017 11:37 AM
I've been experimenting with different injectors on my Carrera for decades and have screwed up more times than I care to admit, so if you are not comfortable (or afraid of screwing up and screwing up is a garantee) or have never done anything like this before, I would do more homework and leave well enough alone. Keep in mind, even something as simple as removing the injectors on a Carrera can be beyond the capabilities of most on this board. Also, I might add, this procedure assumes you have the ability to make the necessary air flow meter adjustments to make these injectors work properly to your satisfaction.
Another I might add is that if you need dyno to tell you how much power you're making and unable to trust your instincts, I would not attempt this.
Cheers,
Joe
bickyd 03-10-2017 12:57 PM
I have rebuilt a few motors in my time and have restored a few cars and trucks. I can do the fuel injector swap confidently. I would like the parameters of the injectors to be as close as possible. I also know that the DME will drive high impedance injectors with little difficulty. I am after finer atomization and smooth running. Maybe a few mile per gallon improvement. The air fuel guage will be adequate. A dyno to me is for competition engines and rebuilders. If I was smart and not stubborn I would just pull the trigger on sals upgrade injector deal. Remap dme , upgrade to 28 pin and injectors. He has done the work already. The exchange rate and the fact I want to play too! My car is at 97000 miles so the oil pump shafts bearings will need doing as well as top end. I know...... there will be more. But that's where the fun is. I really appreciate your words of caution. But I am beyond recovering from this addiction I am afraid. Cheers.
prschmn 03-10-2017 03:57 PM
From the description the problem is certainly not coil related-they only get worse with RPM
though higher range misses can be hard to detect.
And Can't be lack of fuel or that too would get worse higher up in the rev range.
I'll second trying a different AFM first.
Newer style injectors are nice but do cost $ and again I really cant see them being the root of the problem either.
And I will second using Sals stuff over SW any day. Though in the end the only real improvement
is adjusting maps to optimize fuel and timing curves for the current gas as opposed to what the DME was diligently mapped for in 1987.
