Return Oil Line Install Issue
I'm having trouble getting the oil line to line up properly. It's hitting the other oil line and causing it to go in cooked.
I think the last time I had this connected I had the hard pipe not bolted to the tin. Can someone take a look and see if anything looks wrong. https://uploads.tapatalk-cdn.com/201...2a7fbef24d.jpg Sent from my iPhone using Tapatalk |
Picture of the other end........
Matt,
Post a picture of the other end of the oil line. Or better, a full shot of the whole oil line in question. Thanks. Tony |
my S tube rubbed that crimped, fixed line after back dating my SC oil lines for an SSI install back in the day too. I used some bike inner tube to sleeve the S tube where it made contact. in this instance 3" should do.
Here's an overall photo. The two oil lines are touching and preventing the hardlines from connecting properly.
https://uploads.tapatalk-cdn.com/201...c864ec449b.jpg Here you can see how it is not going in straight. I don't want to tighten it for fear of damaging the fitting. https://uploads.tapatalk-cdn.com/201...8c6043faf1.jpg ...and yes my oil cooler is gold. I had it reconditioned by Pacific and they put some kind of coating on it. Sent from my iPhone using Tapatalk |
Oil return line........
Matt,
Loosen the 36-mm nut and slowly rotate clockwise or move metal tube section up. It is installed too low causing it to come in contact with the S-rubber hose. Tony |
| All times are GMT -8. The time now is 05:39 AM. |
