Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 911 Technical Forum
Fender to body seal?
Quick question, on a '70T is there some kind of seal that goes between the front fenders and the body? I don't think there is but checking
Rafik
Old 02-17-2017, 01:26 AM
em78911's Avatar
Yeap, there is a part number for it but I forget it.
Old 02-17-2017, 02:12 AM
Along the bolts is a glue like substance sealing water out and holding the fender on.
At the cowl is a rubber seal to the fender in black
Bruce
Old 02-17-2017, 02:27 AM
Terrastat Tape I think its called. Buy it and roll it out along the fender/body seal flange. 1 roll will easily do the whole car
Old 02-17-2017, 03:29 AM
81SC's Avatar
Terostat ribbon 000 043 129 00
Pelican Parts - European Automotive Parts and Accessories - Porsche BMW Mercedes Volkswagen Audi Saab Volvo MINI
81SC Coupe
Tony Kart/Yamaha
Old 02-17-2017, 03:46 AM
follow-up question: is it really needed?
Old 02-17-2017, 04:43 AM
The Mighty Pieholio
Bob Kontak's Avatar
The front to back seal is on a vertical surface that is roughly on the same plane as the front tire. If the tire is slinging water you know it will try its best to enter the front trunk.
Just talking. Don't know for sure.
1981 911SC Targa
Old 02-17-2017, 06:09 AM
Puma's Avatar
I'm just guessing here also, seems like it would help with vibration, noise, and sealing out grime. My instinct is that Porsche engineers wouldn't have used it if it wasn't necessary.
You could always just try it without and add it later if it appears necessary.
see Pumas 68 resto
Old 02-17-2017, 06:45 AM
No that certainly makes sense. I was thinking of it from the wrong direction.
Old 02-17-2017, 07:41 AM
My car didn't have it when I bought it. After painting my car, I used the sealant strips when I re-assembled the car. My impression is that it keeps water from running down between the body and fenders, but it seems like the weatherstripping would do this as well. It certainly helps to keep the fenders in place relative to the tub, but it makes adjustments of fender alignment more work.
Steve B.
1972 911t
1999 328is
Old 02-17-2017, 08:55 AM
If water gets between the flanges, it will rust eventually. The ribbon/tape provides a very good seal against this, although it makes aligning the fenders a bit harder as it is tacky/grabby as somebody above mentioned
Old 02-17-2017, 02:39 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
