-   -   How concerning are over-rev reports from a DME report (http://forums.pelicanparts.com/porsche-911-technical-forum/946405-how-concerning-over-rev-reports-dme-report.html)
Quickstep192 02-17-2017 03:24 PM
A friend is looking at a 2011 and got a DME report as part of a PPI. It showed a 180 over-revs on the 3-4 range. Is this cause for significant concern?
steely 02-17-2017 03:41 PM
Not saying you won't get an answer, but you might try cross-posting in the 997 forum.
Tippy 02-17-2017 03:48 PM
That's nothing. I had 1000's. Even the Tiptronic was programmed the bang the rev limiter.
180 means 180 times a cylinder was cut. When you are revving 7k plus, that count happens quick. Maybe in 1 rev limit event.
MARISOL78sc 02-17-2017 04:01 PM
Porsche apparently will not CPO a vehicle with range 4 occurrences. That being said I would ask the shop doing the PPI their advice.
MBAtarga 02-17-2017 06:50 PM
Take a gander over on here:
Porsche Rev range activity guide from 911virgin
Until recently ignitions recorded in ranges 3 and 4 were considered by the Manufacturer to be safe with such vehicles still eligible for Porsche Extended warranty. Ignitions recorded in Ranges 5 and 6 would not be considered for warranty with existing policies invalidated at the point of over rev. Current Porsche warranty procedure considers activity in ranges 3 and 4 to be potentially problematic with compression tests and / or oil checks deemed necessary for incursions within the last 200 operating hours.
