DME Schematics
has anyone looked at http://frwilk.com/944dme/ml31dwg.htm
Is this the same DME used in my 1988 911? It must have taken him month of 8 hour days to do this. WOW Does anyone know what S100 a 0127 IC is? It is in the injector driver circuit. Does that do what I think it does and charge the magnetic field in the solenoid and return that energy to the battery? Pretty clever. How about what is S100 a F124038-03 IC. I have access to IHS library at work and I couldn't find anything. I'm curious how the speed sensor works. This is a great find. Armed with this and imaginative parts substitutions you could repair just about anything in the DME. |
marcesq, has the whole factory DME manual. hopefully he'll see this thread and get you the info.
good luck. |
Tim Polzin researched this, you might want to PM him if he doesn't see this thread. From the notes he sent me:
The DME manual is largely a trouble shooting/testing guide. It has good schematics of the external harness and sensors, typical waveforms for the dynamic sensors, but nothing on the internals of the DME itself. My copy is courtesy of Marc.
Its a good thing, but not much help with decoding the internals. Mr Wilke has provided some of the best rference material on the Bosche Motronic that I have seen. The schematic is outstanding. |
Yup, you won't find S100 on the shelf of your local electronics store.
S100 connects to the two flywheel sensors and creates a signal indicating angular velocity. The injectors are on a different circuit (lines 14 and 15, notice that all six injectors are tied together and fire all at once). Most faults with DMEs fall into three catigories: 1) fatigue cracking/cold solder joints 2) results to doing stupid things (shorting ISV lines, etc.) 3) immersion in water 1 and 2 are almost always easy fixes, # 3, no. Tim |
[S100 connects to the two flywheel sensors and creates a signal indicating angular velocity.]
Has anyone busted apart those two sensors? Do they consist of a coil of wire and a magnet? |
-Chris |
Don't mind me while I drag this thread out from the grave. :SmileWavy:
For a personal project on my 944T finding a source for the S100 F12438-03 chip would be extremely helpful. Aside from buying another DME to rape, what are my options? Or is there a way to imitate what the S100 does? Thanks in advance. |
| All times are GMT -8. The time now is 10:53 PM. |
