-   -   Engine Management for a 3.2? (http://forums.pelicanparts.com/porsche-911-technical-forum/94705-engine-management-3-2-a.html)
Roamer 01-18-2003 12:06 PM
I am looking for a user programmable engine managment system (fuel/spark/idle control) for my 3.2 (Bosch monotronic). I am familiar with the UniChip and it seems to fit my needs. Any feedback on this system?
What else is available out there?
Thanks!
stlrj 01-18-2003 02:08 PM
The Unichip is not programmable but the chip is burned for your particular engine.
The air flow meter, on the other hand, is very adjustable and is the main input to the DME for fuel, spark and idle by increasing or decreasing spring tension and adjustment of the rheostat wiper position. In effect, it's equivalent to having the same three dial control for high, low and gain as in programmmable aftermarket MAF systems as in the Huntley Racing or Autothority systems costing $2500 or more.
All your AFM requires you to do is remove the cover to access all adjustment parameters.
Here's a website that shows the adjustments:
http://frwilk.com/944dme/
Click on the air flow meter section for the pictures and don't let the 944 title fool you because the 3.2 meter is identical.
Cheers,
Joe
Steve W 01-18-2003 08:25 PM
Why would you want a programmable engine management system? It's too complicated and subject to breaking down, not to metion the time spent to try figuring if you are too rich or too lean, if you need more advance or retard, and the constant fiddling around. There are already performance chips tuned to do what you want in a much more refined way with factory reliability.
Roamer 01-18-2003 09:42 PM
Steve, I am planning on adding a blower so you can't just buy a chip for it and forget it. I feel I can do a custom set up with little difficulty so long as I have the ability to tune the car to respond to the additional air flow.
Steve W 01-18-2003 10:41 PM
I see. If your blower runs around 6-8 psi max, I think a rising rate fuel pressure regulator may be sufficient. That is basically what some tuners who build turbo systems do, and in high boost situations, increase the duty cycle of the injectors by about 5% and maybe retard the ignition a bit in high load situations. Beyond about 500 hp, larger injectors are fitted. You may also want to talk to another Pelican member, Marc Romanowski, who is also planning to fit a supercharger in his 3.2, however working on a custom chip using a Pro-M mass flow meter.
Roamer 01-19-2003 07:41 AM
Steve, you have revealed my alias! The reason I have asked is to evaluate my options. The Pro-M takes care of the fuel but not the spark. If there are two systems, one for fuel and another for spark, that I could go with, that would be fine as well, any ideas?
John Desmond 01-19-2003 08:08 AM
Here is a programmable connector and pin compatible engine management system:
http://www.lenzmotorentechnikusa.com/LenzPowerKatPorsche.htm
If you are interested I can send you a PDF of the installation
documentation.
Roamer 01-19-2003 09:44 AM
John, thanks. Your system looks interesting. What kind of $ are we talking about for the controller, injectors, and air measurement system? What kind of flow are the injectors capable of?
Roamer 01-19-2003 09:45 AM
A second question to others, can MSD ignition contollers be used with the 3.2?
John Desmond 01-20-2003 07:23 AM
Based on what is posted so far, you will need:
- larger injectors than are in the standard Lenz system
and a different/optimized fuel map
- optimized ignition map
- different pressure sensor than in the standard Lenz system
- stereo lambda regulation (left/right cylinder banks)
all of this is not a problem
how much boost will you be running ?
what are you doing with the exhaust system ?
will you be tuning this on a chassis or engine dyno ?
price estimate would be starting around 3,000
John
