3Ddesigns911's Avatar
What type of stainless steel is the stock heat exchanger
Have a hole on one of my heat exchangers that is repairable, but need to know the specific type of stainless steel for the patch.
Anybody knows?
If it matters the car is an 87 Carrera.
Thanks in advance!
Old 02-23-2017, 11:13 PM
RETIRED
Joe Bob's Avatar
Stock HEs are mild steel AFIK,,,aftermarket ones like SSI and now made by Dansk are s/s. Any muff shop should be able to patch it. Put a magnet on it. S/S has a low magnetic quality if at all. But either way both can be welded.
2012 ML350 3.0 Turbo Diesel
Old 02-24-2017, 07:12 AM
Steve F's Avatar
I general, it will be a 300 series SS+ weldable, 400 series will be magnetic
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate
1967 912-1985 Toyota FJ60 Landcrusier
1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4
1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag
1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS
Old 02-24-2017, 07:16 AM
Anybody knows?
Thanks in advance!
Like Joe Bob says, the stock HE's are not stainless. SSI's were created because the originator of SSI's was tired of patching his steel HE's.
Old 02-24-2017, 07:24 AM
Ray 911s's Avatar
Check the part number stamped on your stock HE. There were two different parts, one ending in 01 and one ending in 00. I have a set of each here, polishing the 00 set.
1977 911S
1973 Alfa Romeo GT Veloce
1997 Lotus Turbo Esprit V8
2016 AMG C63S
Old 02-24-2017, 09:57 AM
I haven't had a chance to check for a part number but snapped some pix. If they are not stainless wouldn't they rust??
Check it out. These are far from new, yet shiny(ish) except for a small hole that rusted out where the tail pipe connects.
Old 02-24-2017, 07:34 PM
Here is a picture showing the bottom of the HE. I took a wire brush to clean it up a bit.... how could this be not stainless???
The part number is 93021102901. When I search for it, I still don't see any references to the material.
Anybody?
Old 02-25-2017, 08:30 PM
