-   -   84, 3.2 Rough Idle (http://forums.pelicanparts.com/porsche-911-technical-forum/947460-84-3-2-rough-idle.html)
hayday 02-25-2017 08:04 PM
84, 3.2 Rough Idle
Rough Idle when hot, otherwise fine when driving and no trouble starting up when hot.
Starts right up and idles fine when cold.
O2 sensor?
Any thoughts would be appreciated....thanks...
http://forums.pelicanparts.com/uploa...1488081462.JPG
DRACO A5OG 02-25-2017 08:36 PM
Disconnect the O2s and see what it does.
jlex 02-26-2017 06:43 AM
When's the last time the ignition wires were replaced? Sounds like with increased heat, there's more resistance on the wires & spark becomes weak. May want to do a resistance test with a DMM. If they're original, buying a new set may be a good idea anyway...
Rodsrsr 02-26-2017 08:40 AM
Check for vacuum leaks first.
