Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Porsche 911 Technical Forum
Brew Master
cabmando's Avatar
Originally Posted by mysocal911 View Post
That's a very rare occurrence when a no spark ONLY condition is the problem.
Then I must be one unlucky dude because I had one with a failed component that created a no spark situation and the car wouldn't start.
Old 03-20-2017, 04:04 AM
scarceller's Avatar
TIP: I use a simple LED test light to test the speed/ref sensors. While cranking the speed sensor flickers the light very quickly while the ref flickers it much slower but still visible. No fancy meter or scope really needed to do a fast quick test.
The other test to do is try another DME from a known good car, it can easily help you quickly figure out if it's the DME or something else. For what it's worth I'm seeing a lot of ignition circuit failure issues in these DMEs, they are over 30 years old and have seen a lot of vibration. It's very possible this is a ignition circuit failure.
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 03-20-2017, 03:22 PM
scarceller's Avatar
Ingo,
I'll also add that re-soldering 30 year old solder is not a great idea. I always remove all the old solder then re-solder with new solder. Then scrub the area clean of all solder flux and finally re-coat the board with conformal coating for added protection. The repair really should be done carefully with the correct techniques, products and tools.
Originally Posted by ischmitz View Post
Re-solder is only one of the reasons the spark output can fail in these DME. If you are handy with a soldering iron maybe you can try to fix it. However, the real test is to measure the signal inside the DME and understand why there is no spark output. If there is a bad component re-solder won't do a thing.
Ingo
Sal
1964 356SC (SOLD)
Old 03-20-2017, 03:27 PM
Hi Sal,
The OP brought his ECU to my house today. My car starts easily and runs fine. We swapped in his ECU and my car would crank, but not start. Later, when I put my own ECU back in my car, it started it immediately.
Just for curiosity, we opened his ECU to look for obvious defects and saw none. I told him that I have worked with you and suggested he consider sending his unit to you or Ingo or one of the other experts for evaluation.
I hope it works out for him soon.
Good luck,
Dave
Dave McKenzie
1984 Carrera 3.2
1984 928S Automatic
2001 996TT
Old 03-20-2017, 04:12 PM
Originally Posted by DaveMcKenz View Post
Hi Sal,
Good luck,
Dave
1. Most of the time without a magnifier, bad solder connections can't easily be identified.
The OP should at least re-solder (clean & re-solder) the problematic ignition driver
connections since the ECM is open and retry the ECM.
2. If that doesn't solve the no start, then Pelican Parts also provides a rebuilding service.
Since this forum has helped the OP troubleshoot thru the 4+ pages of posts and neither
of the two mentioned provided any until the last pages, surely Pelican Parts should be
considered.
Dave
Old 03-20-2017, 04:35 PM
Yes, most definitely the driver circuit has a problem as shown here:
The rare, but occasional driver circuit failure occurs when the vehicle's battery is reverse jumped
for starting or the alternator was over charging (usually an intermittent occurrence).
In both cases, the power transistor is usually destroyed.
Dave
Old 03-20-2017, 04:46 PM
considered.
Dave,
The Pelican rebuilding service costs $540, flat rate(?). The OP may not have soldering skills, yet all he might need done is a resolder of three connections. $540 seems kind of steep for that. If it was me, I would at least call around to see what are my options, such as a bill that includes an inspection fee and price for specific repairs needed. Loyalty to Pelican is great. But...
Dave
Dave McKenzie
1984 Carrera 3.2
1984 928S Automatic
2001 996TT
Old 03-20-2017, 05:04 PM
Dave,
Dave
Given your forum posts, you seem to be skilled enough to do some basic soldering, right?
With your guidance, you guys should easily be able to at least make an attempt at soldering.
Any questions, Google and youTube are your helpers.
Dave
Old 03-20-2017, 05:18 PM
Having met the OP today, I found him to be very competent, and he may well choose to try some resoldering himself. I also wouldn't be surprised that he sent it off for the work. If it were my ECU I might well try to do some of that work myself, but it is another thing for me to "give it a shot" with the unit of someone else.
We'll soon see what happens,
Thanks,
Dave
Dave McKenzie
1984 Carrera 3.2
1984 928S Automatic
2001 996TT
Old 03-20-2017, 05:39 PM
Many thanks to Dave M. for kindly letting me test my ECU in his (lovely '84) Carrera. And, once again, many thanks to everyone who posted on this thread, getting me this far and initiating me into the intricacies of Motronic troubleshooting.
On the advice of several people here, I asked Sal (scarceller) to take a look, and he's graciously agreed.
I was tempted to have a go at the soldering myself, but I thought it better to give it to someone who knows what they're doing (my soldering experience is confined to simple electrical (not electronic) connections, and my technique could use some improvement).
As for Pelican's rebuilding service, I do feel a loyalty to Pelican for making this site available. But I do buy all of my Porsche parts here (and some for my vintage bimmer as well), so I don't feel like I'm free-loading. And, yes, their flat fee is fairly steep if all it needs is touching up some cold solder joints.
Old 03-20-2017, 06:36 PM
Please remember to post the findings and pics of the damaged area for the benefit of this forum !
I can't afford that.
Old 03-20-2017, 07:56 PM
That would have been a good idea while the unit was open, i.e. a closeup picture of the three connections
of the ignition driver.
Dave
Old 03-20-2017, 08:17 PM
I'm pretty sure Sal will provide the findings.
Dave
Dave McKenzie
1984 Carrera 3.2
1984 928S Automatic
2001 996TT
Old 03-21-2017, 03:56 AM
ECU just came back from Sal, who informs me that there were two bad solder joints on the ignition circuit (see photo). Plugged it in and she starts right up. So this long thread has a happy end!
As I mentioned earlier, this has been a great initiation into the world of motronic troubleshooting. I'm grateful to everyone who posted. Special thanks to Sal (scarceller) who was terrific -- very quick with great communication.
If I had to do things over again, I would have saved some time if I had tried my ECU in another car earlier on -- as it was, I was very fortunate that Dave M. went out of his way to offer to have me test my ECU on his car.
So my advice to someone experiencing the same no start symptoms as me would be:
1. Try a spare DME relay, and hope you get lucky.
2. Test for spark (which is also really easy).
3. Plug your ECU into another Carrera if you can.
And go from there.
Old 03-29-2017, 06:31 PM
Just like what was posted a number of times in this thread. Using a magnifier when you and
Dave inspected the circuit board would probably have helped seeing the bad connections.
The re-soldering, as mentioned before, would have taken less than ten minutes including
removal of the old solder. Again, your problem is what occurs in about 90% of all the 911 3.2
DME ECM failures. Hopefully, others will always review the possibility of this failure when
no spark situation occurs and save themselves the cost of a "rebuilding" service.
That's great!!!!
Dave
Old 03-29-2017, 09:07 PM
scarceller's Avatar
What's a rebuild service? I'd like someone to explain exactly what is done in a rebuild service? I don't rebuild DMEs and I doubt anyone does, I fully test them and repair them.
To me rebuild implies MANY components are removed and replaced. I'm skeptical about what exactly you get for a $500-$600 rebuild?
Does anyone know the exact difference between a repaired DME and a rebuilt one?
I've asked this question in the past and know one has yet articulated what 'rebuilt' means.
Sal
1964 356SC (SOLD)
Old 03-30-2017, 03:05 AM
How about we call what you did, and many do, as a 10 minute DIY very minor repair requiring
no knowledge of the ECM's functionally, OK?
Dave
Old 03-30-2017, 04:26 AM
Good work, Sal.
Dave
Dave McKenzie
1984 Carrera 3.2
1984 928S Automatic
2001 996TT
Old 03-30-2017, 04:37 AM
Good point Sal!!
I would hope 'rebuild' includes replacing all the old electrolytic capacitors, and maybe an improved heat sink for the coil transistor since this is a known pattern failure.
And then a running test to check not only functionality, but also that all I/O signals are nice and clean.
Chuck.H
'89 TurboLookTarga, 430k miles
Old 03-30-2017, 04:41 AM
scarceller's Avatar
Why would you assume what I did?
I fully test and verify that every sensor input works as designed, fully test the DME in a running engine and take recording of all sensor inputs with a custom solution I designed and built. Yes I repaired the problem area but I also double check a lot more then just that. Please do NOT assume what others do. It turns out this DME was in good working order other then the bad solder issue. But I do an honest eval on all units.
How about the answer to the "what do others do when they so call 'rebuild' a DME?"
I get nothing when I ask this question.
Sal
1964 356SC (SOLD)
Old 03-30-2017, 04:54 AM
