Intro and headlights
Hello
I wanted to introduce myself and my new to me '87 3.2 Coupe.
It has 117k miles and I am in the process of getting it smogged in AZ; have to switch out the cat bypass/sport muffler to stock set up and change out the SW 93 octane chip to 91 and then I hope to have some fun with it.
Having never driven this era car, it is really a learning experience but thus far it has been very fun! I have noticed that the headlights are not as bright as I am used to (currently have LED) so am trying to figure out what to do. I think current set up is H4 but not sure. Any thoughts are much appreciated!
here are a few pics of her:
Old 02-28-2017, 11:53 AM
Justin@Athens's Avatar
Send a message via AIM to Justin@Athens
Welcome! Nice looking ride you have there, paint looks great! I hate to steer you to another forum right off the bat, but a Rennlister just recently posted about his experience with a LED headlight upgrade. Headlight upgrade: Flat6 Illumination - Rennlist Discussion Forums
Good luck with your car. I am glad I am exempt from emissions here, I cannot believe they expect these 30 year old cars to pass smog.
1990 964 C4 Coupe & 1991 964 C2 Coupe (current)
1989 911 Targa (sold)
1996 993 Cab. (sold)
1999 x2 Boxster (sold)
2006 Cayman S (my daily)
Old 02-28-2017, 12:53 PM
Vintage Owner
Jack Stands's Avatar
I think your car came with H5 headlights from the factory. While not the most popular option for headlights, you might try adding some headlight relaysto see if getting a full voltage directly from the battery may satisfy you.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 02-28-2017, 01:14 PM
faverymi's Avatar
Mmmm. H5s from 1987 are probably foggy inside and pitted on the outside.
If you want better headlights shop around and get something new.
OEM
John Audette's
Guy in Montreal
Nice car. Enjoy
Old 02-28-2017, 01:18 PM
Occasional User
Cook&Dunning's Avatar
Great looking car, congrats. I have H5's too, and have been through a couple of headlight options. I would suggest to not upgrade to higher wattage halogen bulbs - the heat can melt the plastic parts of headlight buckets and attaching rings. I went with aftermarket led bulbs - some here love and some hate, but definitely brighter. If you go led, you do not need to add relays. Search the forum for some led options - plenty of opinions! Might be worth pulling headlights, cleaning insides and maybe replacing/ checking desiccant packs if they are foggy.
Vince
2015 Boxster S, Black & Black
1989 Carrera Silver Coupe, Silk Grey - sold
2009 Cayman S White, Full Cocoa - sold
1972 911E Silver Coupe, Pepita & Black - sold
Old 02-28-2017, 01:52 PM
Neerlandofiel
JordanPryce's Avatar
I'm going to be contrary and say get used to the dim, vintage light. Night is for cruising.
1990 944S2 Baltic Blue 1,960 original miles
1989 944S2 Guards Red 82,000 miles
Gone: 06 Exige, 08 Cayman S Sport, 67 911R Hotrod, 09 Cab, 93 RSA, 91 964, 13 Boxster, 15 Macan S, 05 Elise, 00 M-Coupe, 71 914-6, 75 Carrera, 11 997 GTS etc..
Old 02-28-2017, 02:08 PM
Cars and Cappuccino
tdw28210's Avatar
Welcome a-board! (that NEVER gets old). What took you so long to post pics? You joined in 2013! Anyway, the car looks great. Congrats.
http://www.carsandcappuccino.com
1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits
1985 Prussian Blau M491 Targa
1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe
1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday)
Old 02-28-2017, 02:37 PM
Meant to post this a lot earlier and prior posts cover some of what I wrote below. However, don't think posting it now necessarily hurts . . .
'87 and newer 911s came with h5 headlights from the factory -- these "look" better than the earlier sealed beam sugar scoops but suffer from the same poor lighting/focus. Although h5 headlights look similar to the european H4 headlights, they lack the sharp upward cut-off and beam focus that more recent us-legal headlights now provide. Easiest way to confirm whether you have h5 headlights is to look for aiming tips on the headlights (I believe I see them in your pictures -- NICE car btw), us-spec headlights were required to have these, while european spec headlights weren't.
Few avenues for you to consider --
1) make sure your current h5 headlights are fully "dialed in" -- specifically, properly aimed, cleane reflectors and lenses, good grounds, etc. While this (and the installation of a headlight relay, a preferable update in any situation -- as built, all headlight current passes through the turn signal, adding relays can both increase the amount of power going to your headlights and extend the life of your turn signal, which tend to melt from the headlights' heat/current over time) can incrementally help, the primary constraint with the h5s is their beam pattern, which can't be fixed, only replaced, leading to
2) convert over to european H4 halogen headlights -- you'd need to splice in a different connector to power the headlights and would need to get a trim ring painted to match your car (or rock chrome trim) -- this would give you (especially in conjunction with high watt bulbs) MUCH better lighting once properly aimed, as the h4 headlights have the same well-defined beam cut-off as modern headlights and really put a LOT of light onto the road.
3) look into other aftermarket options being offered -- on this board and elsewhere. Keep in mind that HID lights (one of the options available) require a brief period of time to warm up, which can be an issue if you like to flash your headlights a lot. Further, while there are a few interesting LED powered options, some folks find their more modern appearance to not "fit" with the classic 911's lines.
Old 02-28-2017, 02:47 PM
If you insure the car as a "collector car" in Arizona the insurer notifies the Motor Vehicle Dept and you can be exempt from smog inspections. Do not know what happens if you try for this exemption after first registering the car and later getting the insurance. I got the insurance first, before registration and there was no problem.
Old 02-28-2017, 02:54 PM
Carmagic.us
rothaus's Avatar
For the headlight you can replace the complete H5 with a set of LED, like these.
Just need to replace the plug in the headlight housing, other then that plug and play.
Cheers
Engelbert
For BA7s Dash LED, and External Marker LED go to carmagic.us - Now Luftgekühlt Emblems
Old 02-28-2017, 03:42 PM
Occasional User
When it comes to adding relays - be careful with the H5's - the headlight assemblies are plastic, not metal like H4's and H1's. Lots of melted H5's out there - I know, I have used bought H5 buckets here on pelican that were deformed from heat, and un-useable. (be careful buying used H5 assemblies)
Vince
Old 02-28-2017, 03:49 PM
Seems to me that this would only occur if higher wattage (significantly hotter) bulbs were added along with relays. Unless something else is not right, simply adding relays shouldn't cause a marked increase in heat/light.
Old 02-28-2017, 04:19 PM
Barrpete's Avatar
I'd recommend adding headlight relays regardless of what upgrade you decide to go with. The factory setup has all of the headlight current running through the turn signal/high beam switch. With relays power can be sent directly to the headlights which will also make them somewhat brighter.
1986 Carrera Coupe
1999 Chevy Tahoe
1987 Chevy Blazer
1955 Chevy Apache 3100 Pickup
"A little knowledge is a dangerous thing"
Old 03-01-2017, 08:30 AM
Carmagic.us
rothaus's Avatar
Agree, a set is only $26 and takes about 15 minutes to install.
Cheers
Engelbert
Old 03-01-2017, 09:23 AM
I would definitely us LED H4 bulbs. That is what I have in my 1973 and I love them.
I am not into big trick reflectors and $1000 set ups. Not needed in my mind. Leds last a long time, run cool, draw like 20 Watts and are very bright.
Shop around and get good ones. Should cost less than $100.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 03-01-2017, 01:21 PM
I've got John Audette's with the Trucklite LEDs - works great. On a par with the bi-xenons on my 997
1983 911SC
2005 911S
Old 03-01-2017, 03:51 PM
As a point of clarification for the OP, one would need buy h4 light assemblies to use H4 led bulbs -- As a counterpoint, I've heard that many LED h4 bulbs have issues with cut-off accuracy due to the differences between incandescent (halogen) and led light generation/dispersion.
I find my 911's halogen H4 headlights (with 80 watt bulbs) to be on par with (or better than) the hid headlights in my '04 touarg --
Old 03-01-2017, 04:02 PM
Occasional User
Again - an option for the OP - just add led bulbs to your H5 assemblies. Perhaps a good time to clean the insides. No relays, not messing around. Much better look and performance than the stock POS yellow look. Easy Peasy. Down the road, look at the spendy options if you want.
Vince
Old 03-01-2017, 04:30 PM
Thanks for this tip Hoss!
Indeed, I have collector car insurance and was able to register the car without having to pass emissions. Guess I will just store the cat/stock muffler for now. Just awaiting Steve Wong's 91 performance chip to drop into the DME and then have some fun.
Old 03-02-2017, 09:19 PM
This makes the most sense for now; I will put in a headlight relay as recommended by others. I do like CarMagic's dash LEDs as well.
If I do add the LED bulbs, are they typically plug and play?
Old 03-02-2017, 09:22 PM
