rfix'n's Avatar
Carrera cooler fittings, which side
Does it matter which side of the cooler the supply line is hooked up to? Looks like it will be easiest to fit the supply line to the inside (nearest the trunk) fitting. Return line would then be on the outside or the right side as your facing the cooler.
Not sure if the flow direction through the cooler is important.
Rob Fix
'78 3.6L SC Targa
Eiche Gruen Metallisch
Old 01-19-2003, 11:22 AM
Chuck Moreland's Avatar
Flow direction through cooler is not important.
Are you doing a custom configuration? Because with the factory setup there really is no question how the hookup proceeds, the fittings line right up.
Chuck Moreland - elephantracing.com - vonnen.com
Old 01-19-2003, 11:43 AM
rfix'n's Avatar
not custom, and it looks like it would be really difficult to hook them up the other way. Just double checking to be certain.
Thanks for the reply!
Rob Fix
'78 3.6L SC Targa
Old 01-19-2003, 11:46 AM
