-   -   key blade needed flip type ... (http://forums.pelicanparts.com/porsche-911-technical-forum/947887-key-blade-needed-flip-type.html)
ertech 03-01-2017 11:58 AM
Hi guys need a key blade like this but with the profile for 80's Porsche, I am instaling a keyless system .
picture 2 is the profile needed
thanks
http://forums.pelicanparts.com/uploa...1488398082.jpg
http://forums.pelicanparts.com/uploa...1488398268.jpg
Ken911 03-01-2017 12:33 PM
you will either have to fab one up or try swapping lock cylinders out to accomodate the new type blank.
donporfi 03-01-2017 02:14 PM
Have you tried ebay ?
Porsche 911 Key Blanks | eBay
ertech 03-02-2017 04:49 AM
Yes none on ebay
I am instaling a keyless remote for doors and I need a blade like the 1sr picture but with pic 2 profile
scary driving 03-02-2017 10:18 PM
VAG (VW) guys usually cut a regular key and use that to fit it into the switchblade type of keys. The profile on VW keys is not the same as porsche though. There might be more work required, as in welding extra material where the key screws into the rotating assembly.
Joe Bob 03-02-2017 11:12 PM
If you want the top key to fit the lighted SC style key head, you need to build, weld and cut so it looks like this.
http://forums.pelicanparts.com/uploa...1488524986.jpg
Unless there is enough meat on the flip blank to dremel it down to fit the head. I've down it with old plastic headed keys.
