-   -   Window Helper spring (http://forums.pelicanparts.com/porsche-911-technical-forum/947925-window-helper-spring.html)
r_towle 03-01-2017 05:24 PM
I have a broken spring stop on the helper spring for the window regulator.
Tada, Pelican sell that specific part.
So, along with all new rubbers, that stuff is heading my way.
Thank Pelican for stocking this stuff, you help us keep these old S-boxes running.
My question is when installing this part.
http://cdn1.pelicanparts.com/catalog/images/misc/910392.jpg
Do I pean over the bottom to hold it in place?
Not sure what it looked like OEM, I am starting with a broken off pin, laying in bottom of door.
I have the regulator out....
Rich
Dpmulvan 03-02-2017 04:54 AM
Always confusion over these two partshttp://forums.pelicanparts.com/uploa...1488459070.jpg
One on right is not available and that's the one that usually breaks, the other spring pivot goes in center of spring the one you have a pic of. You have to make your own if it's the right one. The left one has a screw in back.
steely 03-02-2017 06:13 AM
+1 , you'll need to make your own.
search for repair methods, this is just one of a few:http://forums.pelicanparts.com/porsche-911-technical-forum/233103-part-found-inside-driver-door-what-2.html
will be cake since you have regulator out. hth
Alex599 03-02-2017 07:27 AM
Here's what I did:
http://forums.pelicanparts.com/uploa...1488468415.JPG
r_towle 03-02-2017 02:33 PM
I ordered this.
I will make it work...
ITs at least close to what I need, I can grind it to fit and I guess I will pean it over to hold it in place, like the original.
if not, I will be making a bolt setup.
rich
r_towle 03-02-2017 02:39 PM
thishttp://forums.pelicanparts.com/uploa...1488494343.jpg
Dpmulvan 03-03-2017 04:37 AM
That part is for the center of the spring it won't work trust me. We've all been there.
sky1jord 03-03-2017 09:12 AM
+1
You'll be sorrr-eeee. Pay attention to this board, most here have been there, done that.
