Ray 911s's Avatar
Repair, or recycle
This gouge goes through the air box tin and into the actual exhaust pipe. I suppose it would be possible to remove some of the exchanger tin with a cut-off wheel, weld up the pipe, straighten and repair the tin, then weld the exchanger tin back in place.
Or throw it away.
It's from a 1986 3.2L. Thoughts? Dime-a-dozen and not worth the effort?
1977 911S
1973 Alfa Romeo GT Veloce
1997 Lotus Turbo Esprit V8
2016 AMG C63S
Old 03-04-2017, 03:39 PM
Bill Douglas's Avatar
I think cut a section of sheet metal off and see if the header is dented as well as being pierced. I would weld the hole if it looks reasonably OK.
Old 03-04-2017, 04:10 PM
