Question Blasting and cleaning
Morning Pelicans:
I'm half-thru my '83SC suspension refresh, and have a few questions:
  • I've had my control arms powder coated (American Stripping in Manassas, they look awesome, will post pics later!) and they did a good job masking the splines of the torsion tube. However, that means that some surface rust is still there on the splines. Can I have the splines media blasted to remove that surface rust? Any other advice before I start mounting the items to the car?
  • Likewise, I've got my trailing arms out, and there's 33 years of muck and grime on them. Will I be able to have these arms blasted as well? Looking to remove the grime and beat back some of the patina.
Thanks, Pelicans!
Old 03-07-2017, 04:41 AM
OffCamber00's Avatar
HA! I used American Stripping to do my arms back in 2006 - glad they are still in business.
If it really is just surface rust, you can wire brush it off and then treat it with some Kroil/Gibbs, etc and then re-scrub. Once you grease them up to re-install you should be fine.
Mat P
1988 911 Carrera
Old 03-07-2017, 06:11 AM
Eng-o-neer
Tremelune's Avatar
Could just use a wire brush on the splines. The whole bar should be coated with grease to prevent further corrosion.
You can definitely have the trailing arms cleaned and refinished. I believe they're just bare aluminium. Tru6 is a plater that frequents Pelican, and I've seen some great photos of refurbished trailing arms (though I cannot seem to find them at this moment). Lots of other places nationwide, too.
Old 03-07-2017, 06:36 AM
cary's Avatar
Trailing Arms.
3 to 4 10 minute cycles thru a heated jet washer then soda blasted. When finished water rinsed to remove any soda and blown dry. They will come out looking like they just came off the shelf.
Cary
77 Carrera RS w/3.2 #59
73 914S 2.0 AG
73 914 1.7 Driver ( daily driver, under complete rustoration )
74 914 2.0, 71 914 Tub, 74 914 2.0 Tub + 73 914 donor
Old 03-07-2017, 07:08 AM
Awesome, thanks.
Originally Posted by cary View Post
Trailing Arms.
Old 03-07-2017, 09:42 AM
