seafeye's Avatar
What year car did these calipers come from?
As the title says. Looks like I have early suspension but later calipers. Any idea what year car they are from?
I want to rebuild them but not sure of what parts to buy.
What me speed?
Old 07-07-2016, 11:00 AM
faverymi's Avatar
They look like front carrera calipers because of the spacer.
Old 07-07-2016, 11:26 AM
RETIRED
Joe Bob's Avatar
Ask Eric at www.pmbperformance.com or Bill Verburg.
2012 ML350 3.0 Turbo Diesel
Old 07-07-2016, 11:27 AM
gearhead
Isn't there a date on the casting?
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 07-07-2016, 11:53 AM
Yuppo.
206 637 4071
Old 07-07-2016, 12:24 PM
seafeye's Avatar
Don't see a date... But here is another pic. Thanks for the responses.
What me speed?
Old 07-07-2016, 12:42 PM
gearhead
I thought I had seen Bill post at one point about dates calipers. I didn't find it with a quick search, but here's his reference sheet with measurements. This will let you figure it out for sure:
Brakes
1974 914 Bumble Bee
2009 Outback XT
Old 07-07-2016, 01:43 PM
Bill Verburg's Avatar
It's an A front, all have 3.5" mounts and 48mm pistons.
if the spacer between the 1/2s is 7mm they are off a '76 thru '83SC or Carrera w/ a 20mm rotor
if the spacer is 11.3mm they are off of a '84 thru 89 Carrera, still have the same 48mm pistons but the rotor is 24mm thick
Bill Verburg
Old 07-07-2016, 02:30 PM
They look identical to my 1984 Carrera calipers.
But listen to Bill, he is the total master when it comes to this stuff!
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 07-08-2016, 05:42 AM
seafeye's Avatar
Ok. Looks like the spacers front and rear calipers are 11.3mm wide. Thank you for the responses. I can now order rebuild parts.
Now my next question....
The front suspension is looking like it was for a SWB car. My car is a 1971 911E. Yes this car is full of surprises.
Can the later control arms bolt up to the older steering rack and crossmember?
Would I get any benefit from trying to source a complete front suspension from a later car or is the SWB sufficient?
What me speed?
Old 07-17-2016, 03:01 PM
